Bobcat t770 or t870 for mulching?
   / Bobcat t770 or t870 for mulching? #1
CustomConstruction
Hazlehurst MS
Im trying to decide whether i need to buy a new bobcat t770 or t870 for my new mulching machine? I will be running new 2 speed bobcat head.. Help from anyone?
   / Bobcat t770 or t870 for mulching? #2
Welcome to TBN. :)
   / Bobcat t770 or t870 for mulching? #3
Perhaps you may want to post your thread in the specific Bobcat forum here on TBN. Welcome aboard. :tractor:
   / Bobcat t770 or t870 for mulching? #4
WELCOME to TBN :)
I moved your thread to the Bobcat Construction Equipment Forum.
   / Bobcat t770 or t870 for mulching? #5
I use the s750 and I'm pretty happy running a single speed FAE/Cat mulcher.
the t770 and t870 will give you a little more engine power to support the pump but hydraulics are virtually the same.
I was pretty set on the t870 but im not sure if the extra size and weight will be worth it.. The t770 will be the ideal machine for me if it will run the mulcher as good as the t870
   / Bobcat t770 or t870 for mulching? #7
I don't think you will see a big difference in the 870 vs 770. The motor is the same, both turbo, both have similar torque, and hydraulics are within .5 gpm.. That motor at 99hp vs 92 hp is going to be moving almost 2000 lbs before you add the A/C glass and lexan cab, mulching kit, and mulcher which is about 1500 lbs heavier than a standard bucket. You will probably be looking at, and I'm guessing, 14.5k lbs with a T870 loaded for mulching.. that's a lot of weight to move.
Bobcat's hydraulics aren't not that high to begin with in the auxiliary circuit. I'm hoping they update or come up with a kit to get more pressure or more GPM out of these machines. The motors can certainly support it in my opinion.
Don't get me wrong. If I could haul that kind of weight, I'd probably be interested in a T870 but then again, it's a little wide for mulching when the big mulcher is only 60" cutting width. Go wider and you are putting more of your precious hydraulic power into more teeth/cutting surface. The less the better for a compact unit.
Let us know what you decide.. i'm interested.
Hauling the t870 is no problem for me.. Im just really concerned with how much the tracks will stick out past the mulcher more than anything else.. There will be alot of material for the outside of the tracks to run over that the mulcher doesnt cut
   / Bobcat t770 or t870 for mulching? #9
i own a 870 very nice lots of power. i have demoed the 320,770 and 870 the 870 is the best it is a little wide sometimes but its ok with me. im running a 60inch head.
   / Bobcat t770 or t870 for mulching? #10
the 320 is crap to me too small and the 770 nice but where i live very hilly and the 870 feels safer on hills
Finally took delivery of my new bobcat t870 with 2 speed bobcat head... Have been running it for about 3 days now.. I love it!! Makes my cat old cat 287c seem like a pile of junk.. It cuts larger material much easier than the cat, cab sealing and a/c is amazing, it can run all day with no hydro or water temp problems and its been a little over 90 degrees, doesnt ride as great as the cat but the roller suspension is nice and knowing that i will not be rebuilding torsion axles is nice. Over all in my opinion i think its going to be a great machine.. Looking forward for some chipper teeth for the bobcat head though
   / Bobcat t770 or t870 for mulching? #12
I have a T770 on the way. 60" forestry head, A91 cab, roller suspension & joystick controls.
Hope to be posting pics soon.
Here are some pics of my new t870
   / Bobcat t770 or t870 for mulching? #14
Nice. I have a T770. and they are a powerful machine, /what option package did you get ?
Mine is a 071 missing some of the higher end goodies but i still like the power.
I have the A91.. I was going to go with 71 but im glad i didnt the computer display and all the funtions it has are really useful
   / Bobcat t770 or t870 for mulching? #16
I was afraid you would say that. My Deere machines(319D and 333D)seem to have more hydralic power than my T770 but the Bobcat easier on my body to operate due the suspension. Both the Deere and the Bobcat are very nice CTL's......Good luck with yours.
   / Bobcat t770 or t870 for mulching? #17
mine showed up today.
   / Bobcat t770 or t870 for mulching? #18
Congratulations on these new toys
   / Bobcat t770 or t870 for mulching? #19
This thread is a year and half old so maybe the guys that are running a 770 and an 870 could give some feedback... I am in the process of deciding between the 2 and would love to hear what you have to say. Issues, maintenance, power, like or dislike? I would love the 770 for the size but is it enough? Thanks
   / Bobcat t770 or t870 for mulching? #20
I'm curious about how well the plastic parts are holding up. It looks like a lot of what was steel is now plastic. Any problems?
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
PIN PULL AERATOR (A60430)
PIN PULL AERATOR...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
JOHN DEERE 4450 TRACTOR (A60430)
JOHN DEERE 4450...
