Bolt on cutting edge on bucket
   / Bolt on cutting edge on bucket #1
stoyan79
Kubota L3700SU, TYM 4820CH
Those TYM/Branson buckets seem kind of light duty.
Brand new bucket is already drilled for cutting edge from factory.
Is bolt on cutting edge a must have on these?
   / Bolt on cutting edge on bucket #2
Well, "must have" is kind of an over used term, in my opinion.
I don't have one (bolt on edge) on mine. I thought I wanted one when I first bought my tractor, but honestly, for my uses, it hasn't really been something I've missed having.
Not sure what your uses would be, we're all a little different in that respect.
I have dug into dirt piles, gravel, etc, with mine. But I don't do a bunch of dirt work, just "here and there" really. So far it's not something I've needed.
   / Bolt on cutting edge on bucket #3
Depending on how hard you are on your tractor you might want a cutter bar. I opted for the Heavy duty bucket on my Kubota and already have a slight bend in it. Now I have to straighten that out before I put a bar on it. I wish I would have just put a bar on it from the get go.
   / Bolt on cutting edge on bucket #4
I have a HD bolt on tooth bar on my bucket. It's a HD bucket with a HD cutting edge. The tooth bar helps "bring up" the loose stuff on the ground.
   / Bolt on cutting edge on bucket #5
I have the piranha tooth bar on mine and for the cost, it was probably the best purchase I've made for the tractor.
   / Bolt on cutting edge on bucket #6
I'd disregard those existing holes and simply install a Wicked Toothbar with two side bolts. It will greatly strengthen and increase bucket ability!
Travis
2024 Chevrolet Tahoe SUV (A56859)
2024 Chevrolet...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2005 Jeep Wrangler 4X4 SUV (A56859)
2005 Jeep Wrangler...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
