Bolt Thread ID???
   / Bolt Thread ID???
Tx Jim: The M16 is way too large for this particular hole.
Kcender: Good idea, but I just couldn't find one yesterday that would work. Not to say there isn't one, just didn't find it.
Baby Grand: I'm not in favor of the big box stores and unfortunately they are the only ones open past noon on Saturday. The M12 I bought from Lowes was a whopping $4.17 for one. I thought if someone knew the thread size I could call around and save time driving around searching.
What am I trying to do? I thought about making some kind of splash shields/fenders. During snow season I'm getting tired of all the spray coming from the wheels as I travel between my neighbors to clear their driveways. Thought I'd take advantage of the taped hole to mount the bracket. Only plan on keeping them in place when the snow blower is on.
Regards
   / Bolt Thread ID??? #12
I hear you about places being closed when you need them to be open!
   / Bolt Thread ID??? #13
Moship:
I cannot tell exactly where you are located, but in my neck of the woods there is a smaller local hardware chain that carries a huge selection of metric bolts. I too am working on a project on my L4310 which I am sure is a little different than your Grand L, but so far, I have found that all of the holes tapped in the block and transmission are fine thread. Do you have the bolt? There is a website call Bolt Depot they have a bolt sizing chart that when printed out at 100% gives an accurate representation of the metric thread diameter and pitch. I had to use it to size the mount bolts for my ROPS which turned out to be a somewhat rare 14MM fine thread. You can also purchase bolts from them, but I would check around fo one of those real hardware stores locally first. Anyway, I found the site to be helpful. I also found that the unused tapped holes in the block and transmission needed some judicious cleaning to get the paint out of the threads. The was a long process and involved the use of a grooved bolt and lots of penetrating oil. Good luck.
   / Bolt Thread ID??? #14
Could you just tap the hole in loader frame to say 1/2" thread and use a shorter bolt without going into the tractor frame?
   / Bolt Thread ID??? #15
ibnxe: Thanks, but I was aware of the multiple thread types for metric, but buying the different sizes at Lowes or TSC is impossible. It's definitely a fine thread. I tried getting my thread gage (from tapping set) into the hole, but it is too large to fit within the hole. (Yes, there are threads in there)
Spiderlk: Tried that the 7/16-20 figuring that it might be SAE vs Metric but the bolt felt a bit loose in the hole. 1.25 metric pitch is almost identical to 20 pitch SAE. Thanks for the suggestion though.
number two: All the other bolts that assemble the subframe are metric, but I guess it could be threaded either way. It shouldn't be that hard, but it's not like I can find a place that sells all the different types of metric thread combinations.
I have SAE fine threads in a variety of sizes. A 7/16-20 goes in but feels loose. 1/2-20 won't go (diameter is too big).
I also tried searching the various parts drawing on Messick's but can't find anything that utilizes this hole to find the corresponding thread size.
I appreciate everyone's thoughts/suggestions.
Its a "dirty" 12 x 1.25 hole then. Chase it with a cheap tap from HF. That or thread in the 7/16 soaked in Kroil and tap/wiggle it a bunch with a hammer - then use moly on the 12mm. ... Is there one like it on the other side?
   / Bolt Thread ID??? #16
Did you manage to find another bolt from the tractor that will fit? Fastenal will have the bolt you need if you can find one and measure it. Also they sell a bolt and nut thread gauge for about $12 that has SAE and metric thread gauges which if very handy for determining thread on bolts and nuts but it is useless for determining inside dimensions like you have.
   / Bolt Thread ID??? #17
Its metric, look a head of bolt, numbers mean metric
   / Bolt Thread ID??? #18
It is probably metric because it doesnt match American. The bolts that are definitely metric are the ones threading into the tractor. The threads in question are in the loader frame.
   / Bolt Thread ID??? #19
Moship, have you inquired at your local dealer? They should be able to look it up and sell you what you need.
   / Bolt Thread ID???
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
UTV (A49461)
UTV (A49461)
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
2013 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
