Bolt with "10" on the head
   / Bolt with "10" on the head
Wow. 4 broken? Were they all in the same area/same side?
Yep those hardened bolts are murder on drills. Just keep to low speed if you can. Have you been in touch with the dealer about it? Definitely get a paper trail behind you, if you haven't.
All on the same side. Dealer went out of business.
   / Bolt with "10" on the head #52
Would your tractor still be under factory warranty? If so, get the next closest one involved/informed of what's happened. Take heaps of photos just in case there's further issue with that hub in the future. Not saying there will be issues, but that is extremely unusual for so many bolts to be broken and missing on one assembly. It most likely has just been a torquing problem is my view, and as they've gone west the strain has gone up on the remaining bolts. So pleased you found it when you did.
   / Bolt with "10" on the head #53
The CAT bolts I am familiar with are far in excess of grade 8 I believe and are as tough as I'm familiar with. I've seen $10-$15 bolts. CAT may carry grade 8 or use them in a lot of applications or sell in a counter rack but they primarily use/carry/stock some sort of alloy or extra heat treated bolt for use in CAT severe applications and are very expensive. For example, bolts for dozer tracks would have to be much stronger or harder than grade 8. Aerospace bolts are one offs that aren't likely to find their way into the industrial market although I think I have seen some auction off at a gov't surplus sale.
Related to this, I had a log winch from Norway once that came with a couple of alloy log chains. They were about four times the price of grade 70 chain but were as tough as they come. If I can ever buy alloy anything in hardware or related that's alloy and heat treated I buy it.
   / Bolt with "10" on the head #54
Very important to torque bolts especially the high strength variety. The bolt must be stretched into its elastic state to hold properly and not break due to constant flexing.
   / Bolt with "10" on the head #55
Very true. Also LocTite those kin dof bolts because they are subject to so much vibration. Blue--medium LocTite is sufficient. I used to be plagued by loose bolts that worked loose until I started to LocTite most everything. Now, not a loose bolt I can rememeber. None on lug nuts, however.
   / Bolt with "10" on the head #56
Yep agreed... often the reason is to keep the structure in tension throughout the stress cycle vs. letting it go into a compressive state. By doing this, you increase the fatigue life significantly.
I am a big fan of blue LocTite especially on cheap bolt/nut combos that typically come in a DIY put together assemblies of whatever. The tolerances and QA of the low quality threads back out much more easily than tightly controlled fasteners when subjected to vibration.
   / Bolt with "10" on the head #57
My guess is that it is simply means a 10mm bolt of indeterminate grade mfg somewhere in a jungle clearing in Asia. Doubt that a bolt of that size (and purpose) would have been manufactured to meet some amazing standard. The fact that some bolts loosened out indicates to me that the tractor mfg didn't apply standards akin to constructing space rockets.
   / Bolt with "10" on the head #59
I need to replace some broken bolts on my tractor's front axle. They have a 10 on the head, not sure what that means. Any ideas?
I have a 3/4" bolt, grade 10. So they exist.
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A59904)
2012 INTERNATIONAL...
