Boomer - 3 pt lever sticking
   / Boomer - 3 pt lever sticking #21
Due to this thread, I adjusted mine over the weekend and other that my SCV being in the way it was not a big project. But sure made it nicer to use.
   / Boomer - 3 pt lever sticking #22
I finally got around to doing this and it sure is smooth now! I didn't take the tire off and don't think it would have helped. The problem is that there just isn't much room to work in there under the fender well. Having dual rear remote hydraulics made it a little worse, since the levers got in the way. It took me about 20 minutes to work the cotter pin out. I didn't put it back in, I put a hitch pin clip in place of it in case I have to adjust it again.
The castle nut takes a 7/8" wrench and I had to move the 3pt lever back, put the wrench on the nut, then move the lever forward to loosen the nut. I loosened it 1/3 of a turn.
I attached a picture of it, side view.
   / Boomer - 3 pt lever sticking #23
Another picture of it, rear view. If you look close you can see that a tab is broken off my castle nut, but the other side has tabs on both sides of the clip, so it should be OK.
   / Boomer - 3 pt lever sticking #24
Thanks for the good pics. I have the rear hydrolics in the way also and have been wondering how to do it.
Nice pictures Danny. I can see why others have had more difficutly. Things certainly are a little tighter in there than my TC40D, but glad it worked out OK.
   / Boomer - 3 pt lever sticking #26
Danny
Thanks for the pictures and helpful hints. I have 2 remotes also. I was able to get the castle nut loosen this weekend. The 3pt lever works much better now. Per your idea I used a hitch pin clip also. Much easier to install/remove than the cotter pin.
To remove the cotter pin, I straigten it as much as I could with a needle nose. Then I used the hooked end of a brake spring removal tool to pull/pry the cotter pin out. It seemed to work pretty well.
   / Boomer - 3 pt lever sticking #27
tpaulson - "To remove the cotter pin, I straigten it as much as I could with a needle nose. Then I used the hooked end of a brake spring removal tool to pull/pry the cotter pin out."
That was a great idea! I used a screwdriver and pushed it into the head of the cotter pin from the side and then pryed it out. It's taking me a while to get used to it now, it moves so easy and I'm used to having to push hard so sometimes I go too far. But, once I get used to it I know I'm going to like it much better!
Many thanks to djradz for the original post!
I too didn't think of a brake removal tool, but used a screwriver and needle nose pliers. Did a lot of grading blade work this last weekend and can't imagine not doing it without having the control move smooth and easy. Many thanks to J Inman and others who originally proposed this.
   / Boomer - 3 pt lever sticking #29
new method:
I couldn't see the cotter pin due to the remote in the way. couldn't see it from behind either, thought it fell out, so I put the wrench on it and give it a 1/3 turn (by pushing the lever forward while wrench stayed stilll). NOW I can see the cotter pin! It's a bit bent, but intact and in place. And now my lever moves SMOOOOOOOOTH. Total time, 3 minutes?
Wouldn't have done it by choice, but it worked and seems fine. Not going to mess trying to get it out now to replace it.
   / Boomer - 3 pt lever sticking #30
Its been too long since I've been on TBN or my TC40D! I'm recovering from the flu and thought some reading on TBN would be good for recovery /forums/images/graemlins/wink.gif. This thread unfortunately reminded me that I wanted to deal with this years ago and yet never did.
Well, since we are expecting 5-9 inches of snow in the next 24 hrs I thought it might be nice to have a snow blower that dropped smoothly instead of jerking that nearly catapults the contents of the FEL out on the ground.
Doing the fix took roughly 1hr of which 55 minutes was spent running back and forth to the house and or other building to find/borrow tools that would work within that tight area. But it sure works great now! /forums/images/graemlins/grin.gif
Thanks guys for the reminder! (Once it warms up a little I'll try the same on the throttle too)
Trailmobile Van Trailer (A56435)
Trailmobile Van...
2006 Ford F-450 4x4 Service Truck (A56858)
2006 Ford F-450...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2019 TAKEUCHI TL10V2 SKID STEER (A52709)
2019 TAKEUCHI...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
