bota spits and sputters,dies out then comes back to life
   / bota spits and sputters,dies out then comes back to life #21
I substitute a piece of clear fuel hose on the last run to the injector pump to check for air bubbles when I suspect an air leak. This will help you tell for sure if you have a problem on the low pressure side. I don't think the oil sender is involved in fuel pump operation, if that is the sender you had disconnected.
   / bota spits and sputters,dies out then comes back to life #22
Take it to the dealer while it is still under warranty. If they figure it out, great, it cost you nothing to get repaired. If they can't find anything and something goes wrong after the warranty period, you can point to the fact that they couldn't find it when it was in. A good dealer will work with you even after warranty is over. Wash all the diesel fuel off the engine and frame before bringing it to the dealer. No one wants to work on a oily engine. Dusty
   / bota spits and sputters,dies out then comes back to life #23
If you smell diesel but don't see white smoke coming from the exhaust, you have a leak that is dripping diesel on a hot surface and it is evaporating. That leak, when you find, it is probably the source of your problem. Any spot that can let diesel out of the injection system can let air in.
HI
Friday when i got home,i started digging ditchs with the hoe.Before i got her out,i topped it off with fuel,and decided to try some powerservice in the tank.once in 3 hours did it sound funny,and smell of fuel.
Today,i topped it off,added another shot of it to the tank.The tractor ran flawlessly all day,just like new.My conclussion is the air finally worked it self out ,or more likely the tank had water in it.POWERSERVICE RULES!!!Thanks everyone
AlAN
   / bota spits and sputters,dies out then comes back to life #25
Doubtful.
The smell of diesel fuel tells me there is a leak, at least intermittently. Fixing leaks, at least up til now, is not something Power Service claims to do. Yet.
Let me ask this then,If i take a tractor back to the dealer,that seems to be running fine,and request the a compression test on the engine,A pressure test of the injectors etc.How long will this take normally.I bet ill have to foot the bill,if nothings wrong right?I feel like im da..ed if i do,da..ed if i dont.Is these test an all day affair?Excuse my ignorance,this is my first diesal.
ALAN
   / bota spits and sputters,dies out then comes back to life #27
There is no need for a compression test or a pressure test of the injectors. You're right; if you go in and tell the dealer to do those unnecessary tests, they probably will charge you.
What you DO tell the dealer is just what you've told us here--accurately describe the symptoms of your problem and ask them to please fix it, as it is still under warranty. End of story.
   / bota spits and sputters,dies out then comes back to life #28
Dusty gave you some real good advice. The only place I would disagree with him is I would say DON'T wash it...stains, etc., can be a help in finding leaks.
   / bota spits and sputters,dies out then comes back to life #29
If he doesn't clean it, then the engine will have lots of oil stains that are not relevant because of his bleeding the injectors. A clean engine with a leak is a lot easier to find than a dirty engine with a leak. I am not certain, but I believe that the red fuel dye will also fluoresce under a black light. I will have to try this once it is dark on my own tractor. I also know that there are dyes that can be added to the fuel to locate leaks, but the kits to do this are expensive and are only practical for dealerships where there use would warrant the cost. Dusty
   / bota spits and sputters,dies out then comes back to life #30
Good point. I guess I overlooked the fact that he's cracked open the injectors.
   / bota spits and sputters,dies out then comes back to life #31
OK - so I add Power Service all the time to every tank full - like church on Sundays...
But - can you / should you add Stabil to diesel too?
   / bota spits and sputters,dies out then comes back to life #32
No dieselservice is all you'll need.
Theres several dieselservice products to use for differing situations but the DS in the white bottle is good as a preventative and it also up's the cetane which is similar to boosting the octane in gasoline....
HEY FOLKS,
Itook my tractor over for a check,and iam picking up tommorow.They said the injectors and the engine check out fine ,and confirmed i had already corrected the problem with the filter clamps,fixing the air sucking and that i probably had some water,and the power service corrected it.
They checked the 23 over from head to toe,and the only issue was a very loose sending unit in the tank in which made the gauge wacky,and why i ran out of fuel.
It would be my reccomend if you change filters switck to the water pipe type clamp,in stead of the wire type.
The power service is great stuff to.I got to get rid of those old metal cans,thats probably where some of my water came from.
I had the tires topped off with ballast now bring on the snowbankings!!!!!!
Thank you all,IM GETTING MY BABY BACK TOMMOROW!!
alan
   / bota spits and sputters,dies out then comes back to life #34
You both can and should add stabil to diesel fuel IF you are going to have the same tank of fuel in it for more than about a month. I use both stabil and powerservice this time of year adding it to the tank and to the 5gal jugs of fuel.
You should also let the service station know that you suspect that they had water in thier fuel. Not an accusation, just let then know that you as suspicious.
jb
   / bota spits and sputters,dies out then comes back to life #35
I've only put a total of 250 hours on my Kubota, but have never used power service or stabil in it and have never had even the hint of a problem. In fact, the fuel I used all this time is from a tank that I had filled almost eight months ago, which is just now empty. Am I just lucky or is there some powerservice benefit that I am missing here? I run the tractor no less than weekly, often times every other day.
   / bota spits and sputters,dies out then comes back to life #36
escavader said:
Ifound something.On the side where the oil filter there was a wire off something that looked like a temperature sensor.I plugged it back in,but i had no time to test it.I unloaded it from the trailor and put it in the garage.I will have to work it tommorow night and see if that was it.The temp gage was working so it cant go to that.SO WHAT IS THIS THING AND WHAT DOES IT DO? I must have knocked it off changing the oil.ALAN
You need to get to Tractorsmart.com and get the parts break down for your tractor. It will show what everything is. If your tractor starts and runs, you don't need to keep cracking injectors to bleed air. Once it is up and running, your good there. If you are not getting fuel to the injector pump, many times it is the fuel delivery pump. I have no idea if your tractor een has one as many Kubotas have a gravity feed system if I am not mistaken. You may have a air bleed valve like my Kubota. If I leave it open, it will act up much like you describe. It is located very close to the injector pump. It will run with this valve open, but it does need to be closed once the tractor gets going. We had a problem like yours on a Kubota L4840. There was a blockage in the fuel delivery stemming from the tank outlet. Seems a bit of mud got into the diesel can which in turn ended up in the fuel tank blocking most of the fuel flow. It was obvious by looking at the clear fuel filter bowl that there was insufficient diesel in the filter system. If you can see your filter and the housing is not full all the time, you have a delivery problem.
HI RAT,
My tractors all fixed now.The wire on the block went to one of the gauges,and wasnt the problem.When i changed my fuel filters,the original clamps did not seat the hoses correctly,allowing it to suck air.After a large dealer in central maine told me that they make it a practice to change the clamps to the screw type[like for water pipes] because its hard to get them to reseat exactly like they were before.For like a dollar i replaced all four clamps and the tractor bled itself and i was good.However i think i got some water in my fuel also ,and it would sputter now and then.The power service cleared up that.The tractor was running like new for the last 20 hours ,but i took it in for a checkup,to make sure,because my warrenty is about up.
Hi 5030 tinkerer,
I use the power service usually only in the winter to prevent gelling,it gets darn cold up here.However my neighbor who is a diesal mechanic told me to dump some in to see if it clears up my latest problem,which he suspected to be water,and it did clear it up.
hi john bud,
Im not sure it was the ststion.I notice them metal cans swett terrible in the summer in my barn,i suspect i need to replace them.
ALAN
Club Car 4x4 Diesel Utility Cart (A59228)
Club Car 4x4...
PALLET OF (3) CABINETS (A60432)
PALLET OF (3)...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
(INOP) 2002 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
(INOP) 2002 FORD...
2001 BOBCAT 773 SKID STEER (A60429)
2001 BOBCAT 773...
