Buying Advice Bottom plowing with hydro trans?
   / Bottom plowing with hydro trans? #11
I used one on my 4105 it pulled it real good.
   / Bottom plowing with hydro trans? #12
That being said, hydro farm tractors (I.E. International 86) have been around for a long time, I don't think you will have a problem with it.
Referring to the IH hydro's is not helping the case, lol.
They had major reliability problems under heavy use. Many that are still running nowadays are relegated to PTO work or light chores because the transmissions are shot. It was a good concept, but bad implementation.
That said, the technology today is much different than what they used back then. The current hydro transmissions are capable of being worked just like their gear driven counterparts. The only downfall is slightly less efficiency.
For strictly field work I still like a gear driven tractor. It is nice to be able to have set speeds for different applications and just put it in gear and go. However, If I just had one tractor and it had a loader on it I would go for hydro (or power reverser on a larger unit.)
   / Bottom plowing with hydro trans? #13
It's true that traditionally gear drive is THE field tractor application. However, the eHydro design in theory negates that because you can also set the speed you want and regardless of load, the eHydro will keep the speed by varying flow to the transmission. The computer takes care of it for you unlike a standard hydro system. As long as the reliability is there over 20+ years the eHydro gives you the best of both worlds.
To me, the disadvantage of eHydro is that I might not be able to get parts 20 years later and it is a more complicated system. Gear is easy to work on, as is standard hydro. I don't know if it will matter in practice but there are lots of really great 20+ year old tractors going strong and hard parts are still available. I don't know if fried circuit boards will still be there...
Thanks to all replies! What a great tractor site! :D
Regards,
Mechatgsk
   / Bottom plowing with hydro trans? #15
i agree with those that say the hydro will do good pulling the plow.all you have todo is put it in low an set your rpms an go.i find i use low for just about everything i do on my tractor.
   / Bottom plowing with hydro trans? #16
And unless his garden is several hundred acres, it is not like the tractor will be pulling the load for hours on end. And you only have to plow once a year. I agree it should be fine.
   / Bottom plowing with hydro trans? #17
He also stated that it would be used for mowing and loader work. The hydro works great for that and he'll probably spend a lot more time doing those chores than plowing.
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
Utility Cart (A59228)
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
Pintle Hitch Triple Axle Trailer - NO TITLE (A59814)
Pintle Hitch...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
