Bought a 1964 MF35 Industrial Utility / Turf ( The Yellow One )
   / Bought a 1964 MF35 Industrial Utility / Turf ( The Yellow One ) #11
Even better, it's always better to have a bit of experience on your side. I'm sure you'll have it fixed in no time.
Oh yes, definitely. That's why I am on here. I always prefer to get other opinion's on stuff I either have never done, or even if I have but been awhile since I did. I have learned it saves time in the long run. I tried the link for the manuals. They had nothing on the MF35.
   / Bought a 1964 MF35 Industrial Utility / Turf ( The Yellow One ) #13
Same for me. As for the manuals, they're in there somewhere. The site is a bit difficult to navigate. I'll poke around and see if I can find them. I got mine from agcopubs so I know they've got them.
   / Bought a 1964 MF35 Industrial Utility / Turf ( The Yellow One ) #14
What is the " candle trick" ?
   / Bought a 1964 MF35 Industrial Utility / Turf ( The Yellow One ) #15
Heat surrounding area until it's super hot, melt a candle into it, walk away until it cools.
As everything cools, the wax is sucked into the threads. Most of the time, the stuck bolt/stud/nut can be turned out with little effort.
Lots of Ford guys use the trick on their exhaust manifolds, my brother included. I've used it on a few different very rusted projects and it always seems to work, even where just heat alone fails.
   / Bought a 1964 MF35 Industrial Utility / Turf ( The Yellow One ) #16
I've used PB Blaster, Kroil, etc...penetrating oils in the past with good results. Several years ago I started making my own solution consisting a 50/50 mix of acetone and transmission fluid. A gallon of acetone is around $17 at Lowes. I purchased several spray bottles for a couple bucks each. Works better than anything out there for a faction of the cost.
I have used all of that stuff as stated at the beginning of post EXCEPT 50/50 mix one. That one I will try also before I go to the air tools to remove the manifold nuts. Doesn't the acetone eat up the spray bottles? Or because of the tranny fluid it does not?
   / Bought a 1964 MF35 Industrial Utility / Turf ( The Yellow One ) #18
The acetone plus automatic transmission fluid combination as a penetrating lubricant has been widely discussed in several forums. I tried mixing the two components , and found that they do not form a solution, but soon separate into two layers. Some people say that there originally was a third component . Others say that, despite the separation issue, it still works well. Since I've never tried using it as a substitute for commercial penetrates, I really don't know. And don't worry about acetone eating the spray bottles. If the bottle is polyethylene , almost nothing will attack it. But, the pump mechanism on the bottles may not last for more than a few weeks. ( But, I do plan to try the candle trick !)
   / Bought a 1964 MF35 Industrial Utility / Turf ( The Yellow One ) #19
I tried the first time. Guess I did something wrong. How's This
Hi Rick, would u mind sending a few pics of this tractor to me? I just bought one very much like this and we r having a hard time identifying the exact year...urs is the only pic we've seen with matching rear rims and seat(from what we can tell on ur pic)
   / Bought a 1964 MF35 Industrial Utility / Turf ( The Yellow One ) #20
378467 (A51572)
378467 (A51572)
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51247)
2012 VOLVO DBL...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
WOODS TBW15.40 LOT IDENTIFIER 60 (A53084)
WOODS TBW15.40 LOT...
Manac Walking Floor Trailer (A50322)
Manac Walking...
