Box Blade for JD 2210
   / Box Blade for JD 2210 #11
mhalla,
Will your dealer let you try out a boxblade when the machine comes in? My dealer had some used blades sitting around. This may be a good way to get a feel for the weight. I don't mean that you should necessarily take it home, but maybe hook one up to see what feels "right" for the tractor.
I read your initial post. My needs for the boxblade were similar to yours--I have a 500 foot driveway and I also needed to relocate some dirt. In my instance, I cut down through 10-12 inches of compacted gravel and clay with chunks of cement and concrete block mixed in. Was it possible to spin the wheels? Yes, but the tractor handled the 5 foot boxblade very well. I haven't seen a 50 inch boxblade, but that doesn't mean they don't exist. My guess is the 54 would be a good fit--see what your dealer thinks.
Bob
   / Box Blade for JD 2210 #12
I have a 48" United/Leinbach box blade coming with my 2210. It's the "HD" model, and weighs about 320 pounds. I ordered the 49" loader bucket. The stance of the tractor is 48", as was mentioned.
After a lot of discussion with my dealer and reading dozens of posts here, I figured it was a very good fit. The box blade is half ballast box, half grading tool. The design of the United is perfect for adding suitcase weights if I need more than 320 pounds of ballast. If I hang six suitcase weights on it, I'm up to 572 pounds of ballast; 8 suicase weights gives me 656 pounds, which should be fine for most loader work with the 49" bucket. The box blade color is red, but I figured that it would look like a little slice of Christmas year round behind the green machine.
I'm sure I will be able to reach the tractor's pulling/traction limitations with the 48." You'd just reach it a little sooner with the 54".
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2014 Club Car Electric Utility Cart (A51691)
2014 Club Car...
UNUSED TOPCAT 81" HYD HEAVY DUTY HYD BRUSH CUTTER (A51248)
UNUSED TOPCAT 81"...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
