Box Blade? Opinions if ya got one thanks
   / Box Blade? Opinions if ya got one thanks #2
I don't have one, but ....
395#.
Way too heavy for our B5100 to even lift.
Too narrow & light for the L3240.
Just about right for our B2320 - maybe a bit wide.
What would you pull it with?
I think the mfr for the TSC CountyLine brand varies, depending on where you live.
Sure looks like the KK:
395#.
Too narrow & light for an L3240.
I thought it does also. here is the KK from northern for me theres 230 shipping so a huge difference in price.
King Kutter Box Blade — 60in., Model# BB-60 | Category 1 Blades Scrapers| Northern Tool + Equipment
   / Box Blade? Opinions if ya got one thanks #4
I don't have one but it sure seems like a good deal and the reviews are good.
   / Box Blade? Opinions if ya got one thanks #5
All of the tractor implements at my TSC in Florida have Tarter Manufacturing stickers on them. My computer show the same TSC BB yours does, but that is not what is on the lot at my local TSC.
What tractor do you intend to pull it with? 4-WD or 2-WD?
R1 or R4 tires? Tire width, outside to outside?
Heavy-Duty Box Blade - Tarter Farm & Ranch
   / Box Blade? Opinions if ya got one thanks #6
TSC implements tend to be OEMed by either Tarter Gate or King Kutter. Both have a reputation as a decent quality impliments at a lower price point.
If you want lots of weight and top tier quality, look elsewhere, but bring a spare checkbook. But you probably won't go to wrong with a TSC or King Kutter impliments as long as you size it right.
   / Box Blade? Opinions if ya got one thanks #7
I have a 72" box blade that is painted blue and has LS stickers on it. I bought it from my LS dealer when I bought my LS tractor.
The owners manual states it is a Taylor Pittsburgh Mfg blade. If you do some net searches, you will find that TP supplies implements to several retailers including TSC and KK.
I'm happy with mine. It weighs 500# so it is light to medium duty, which matches its price point. For my general landscaping etc use, it is just fine.:D
Bob
   / Box Blade? Opinions if ya got one thanks #8
We have a Bush Hog BBX60 5' box blade we pull with Kubota B2710 HST (27 HP). Pulls fine but at only 325 lbs. have to add some extra weight to make it work well. I can hang some of my front tractor weights on the front to rear support bars. Think they are about 45 lbs. each and use 4 of them.
Also have hydraulic top link which gives much better control of cut.
Sent from my iPad using TractorByNet
   / Box Blade? Opinions if ya got one thanks #9
I have the KingKutter 6' box blade (bought used and refurb'ed). I've looked at KK, County Line, Tarter, and the LS labelled box blades. The Tarter and County Line 6'ers are listed online weighing 445 lbs. The KK weight online is listed at 500 lbs (actual weight of mine is 490 lbs). Jaydee claims the LS BB weight is 500 lb. All 4 look very similar in build structure.
When I was looking, I asked a few questions here and was told the implement width should cover your tracks which is why I got the 6'. A 5'er would have been 6" less than my rear tire width.
I know my local TSC store used to sell KK and now sells County Line. The FL store mentioned sells Tarter brand and I suspect they some TSC's also sell Taylor Pittsburg.
It's a good blade but not as heavy as the more expensive H.D. ones.
   / Box Blade? Opinions if ya got one thanks #10
Source of weight was specifications in owners manual, not actual verified weight. Should have been more clear.:eek:
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
Ford Tailgate Themed Wall Decoration (A55758)
Ford Tailgate...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
3650 (A47477)
3650 (A47477)
2010 Ford Fusion Sedan (A53424)
2010 Ford Fusion...
