Box blade or grader blade
   / Box blade or grader blade #1
keegs
The County, ME
Kubota M5640SUD
Hi All.
Looking for some tips on maintaining my driveway. 11205500_1206928019320919_503070583236534513_n.jpg 35973311_1994318437247953_8244601560496078848_n.jpg
The driveway material is mostly a gravel mixed with fines that've been covered over by grass. The second image is older than the first which shows how the grass has covered over much of the base material. Springtime in northern Maine is referred to as mud season. This driveway surface gets a little soft but the ruts don't get too bad.
The extent of my grooming has been to drive over the high sides of the ruts as they develop during mud season.
I'm thinking of picking up a used box blade or grader blade but I'm not sure which to get. Price matters and the grader blades are typically more available and cheaper. I have no background on this but I'm thinking I can scrape or bring up some of the gravel thereby firming up and leveling the driveway surface. Am I on the right track so far? If so can you comment on why or why not? And also what length attachment can I go with?
The box blades appear to have some additional function with regard to moving and leveling material. This is an old potato farm and there are a few places in the fields where potatoes were buried leaving depressions. I'm leaning in the direction of the bb but the grader will probably do 90% of what I want to do here as well.
I have a bare bones Kubota M5640 4x4 diesel tractor with no remote hydraulics.
Thanks to you all in advance.
Chris K.
   / Box blade or grader blade #2
If you do not need the center crown, consider a Land Plane/Grading Scraper.
LPGS "recovers" gravel as it levels.
LPGS will level your potato field if it is bare dirt during some period of the year.
VIDEO: tractor land plane grading scraper - YouTube
If removing snow with your tractor is a consideration then a rear/angle blade will offer more versatility.
   / Box blade or grader blade #3
Well - those two pictures show that your driveway is, actually, in pretty good shape. Its stable - relatively smooth - the grass adds to the driveway stability. If it were me - I'd be leaving it the way it is.
The rear blade (grader blade) will clean snow off the driveway, pull material out of the roadside ditches and crown the driveway. It can move material from here to there but is no way as efficient as a box blade at doing this. It has a long learning curve but is the most universal of the three mentioned.
The box blade is very poor at clearing snow in the winter, is good at moving material from here to there, can be used to crown the driveway. It also has a long learning curve.
The LPGS will smooth the driveway, of little value at moving any material horizontally, piss poor in the snow, not good at crowning the driveway. This implement has, basically, a zero learning curve. Hook it up and drive forward. Oh, another point, if your driveway has a crown - proper use of the LPGS will not remove the crown.
I would recommend a rear blade in your case. More uses in and around your property.
snow removal
pulling material back up and onto the driving surface
crown the driveway
move material from here to there - somewhat
can be used to smooth/level the fields
   / Box blade or grader blade #4
I agree with oosik. A rear blade will be the most versatile to meet most all your needs.
Thanks Jeff, First I've seen one of these. The video was impressive...almost no learning curve... A little pricey and maybe not as versatile as the other implements but a home run for freshening up my driveway. ��
snow removal
crown the driveway
Thanks Oosik. I didn't mention this in the original post but some of why I'm considering grading is for cosmetic purposes and to avoid having to mow the driveway (....assuming grading won't be done as often). The grading plane seems to restore /re-establish the gravel surface and looks great. Will the grader blade do this as well? Is there a downside to grading (and disturbing what's there now)?
Used blades are available and prices are affordable. I saw they have combo blades and rakes which might be something to look into. I have a 6' snowblower attachment for snow removal.
   / Box blade or grader blade #7
After reading what others said,look's like I'm in the minority of one on maintaining a drive. I've lived on acreage with rock and gravel drives for over 50 years. The 2 or 3 tines I've attempted reshaping,it didn't turn out well. I read about people routinely rakeing their drive. If I regularly raked,it would take far more new material than if new material is added as needed without disturbing old material. Stated another way,after it set's up, I never disturb it again. I don't have to contend with snow but if I did I would use a straight blade. I've used straight and box blades a lot and prefer box 2 to 1 over straight. Unless your 3 point apply's down pressure,a straight blade will not cut clay dirt,much less a packed driveway for reshaping. If you need to move packed dirt or rock,dropping the rippers on a box will do it. I'll leave you with some thoughts. See if you can borrow one of each to test before buying. For every contractor you see using straight blade,you will see 25 using box. Ground up asphalt removed before state repave's roads is the best topping you can find.
Thanks Jaxs. A rental option would be ideal. Haven't done too much checking on the availability of recovered asphalt but material options are somewhat limited here. There's a small gravel pit a mile down the road from me. The material is mostly screened bank run mixed with fines.. it's cheap and transport costs are low. This is primarily what folks here are using on their driveways .. in some instances they even use it as a base to build on. The frost line here is 6'.
   / Box blade or grader blade #9
Base can be as important as topping. An often overlooked base material is concrete plant wash out. BTW,frost line in Tx is somewhere around 8,000 to 10,000 feet,,,,,,altitude . :airplane:
   / Box blade or grader blade #10
A grader blade is good at leveling loose material, but not so much for what you want to do. I brought a blade home for that same purpose, but it wouldn't even scratch the surface of the sod. I agree that your driveway looks pretty good but can understand why you don't want the grass.
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2018 Nissan Versa Sedan (A59231)
2018 Nissan Versa...
500 BBL FRAC TANK...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59905)
2018 FREIGHTLINER...
