Box Scraper Box Blade prices / opinions..
   / Box Blade prices / opinions.. #1
ChuckinNH
Elite Member, R.I.P.
NH
(B2620, had BX22) Simplicity Legacy w/48" mmm
I'm in the market for a 4'-5' box blade to use on my Kubota B2620. I've seen the 4' Landpride / Woods versions for $625-$690 around here. I have also looked a little at the KK versions at TSC, and the Taylor Made versions, but have no idea what the pricing is like on those. They seem to be built nearly as well as the known brand versions, and my use will not be constant. I will however certainly hook on to big rocks, and probably roots with some frequency! :D Any pricing, or experience would be welcome. Thanks!
   / Box Blade prices / opinions.. #2
I have a Woods GB65...love it, built like a tank...I was in your shoes a few months ago and came to the conclusion that the only ones that were built like tanks were the Bush Hog, Woods & Landpride ones.
   / Box Blade prices / opinions.. #3
The 4' ones at TSC are $400. I've been happy with mine and couldn't see spending the $600+ for a Woods one. If I were using my equipment professionally, it'd be a different story. I don't anticipate ever breaking this BB just toting it around my property. If I do, lesson learned though. :)
   / Box Blade prices / opinions.. #4
I have a BushHog 6' unit that has pulled all sorts of stuff from the ground and does not look any worse for it. Big rocks, 3" tree roots, an old metal wagon wheel etc. I routinly get the box so full of dirt that it gets pushed up under the tractor.
   / Box Blade prices / opinions.. #5
TSC 5' BB for less than $400.00 (on sale otherwise expect $425) Built as strong as any others I have seen. The only real difference was that the TSC brand may or may not have the rear swing blade. It still had a rear blade, however I have not seen many at TSC with the swing type. Brands will usually be KingKutter or FarmForce, both appear to be almost the same.
I just picked one up a couple of weeks ago, plan to use this weekend.
   / Box Blade prices / opinions.. #6
I have a 6' Armstrong Ag BB that I got for $395
   / Box Blade prices / opinions.. #7
United has makes a nice box blade. Box scrape heavy duty
Some nice features include; captured hitch pins, and easily adjustable ripper shanks. Do a search for boxblade comparisons. There is a very good thread on this topic with lots of pics.
Solo
   / Box Blade prices / opinions.. #8
I have a Farm Star 4' box blade bought it at Rual King for $400. Heavy and well made.
Thanks for all the input! It doesn't look like many are disappointed in the BB that they have. Time to go shopping!
   / Box Blade prices / opinions.. #10
Not so fast... check out my post on page 23 of this thread:
http://www.tractorbynet.com/forums/attachments/59301-box-blade-photo-comparision-brands-23.html
and specifically this picture:
http://img.photobucket.com/albums/v145/supercobra/NH/IMGP4594.jpg
Mine finally broke in half. I'll try to take a picture tomorrow. It broke in a place I didn't think it would and all of the cheap box blades look to me that they are built the same way. The teeth pulled right through the sidewall of the tube that they are mounted in. I don't think I abused it. Definately less than 50 hours on it. I only have 300 on the tractor. I've been looking for a new one the last couple of days and even though the better built ones are at least a couple of hundred dollars more, that would've been much cheaper than buying a cheap one, throwing it away and buying a better one.
It is hard to get a look with the teeth in and the BB laying on the ground but try to see if you can look beside the teeth and see how thick that metal is. Mine - a Land Master Box Blade - is a little less than 3/16". Most of the other cheap ones I've seen in the same price range at places like TSC (Farm Force, Dark Horse, the light duty version of the Land Pride, etc) look to be the same thickness. On some models it looks to me like the edges around the hole are even flared so that the metal looks thicker when you are looking at the edge. Maybe this isn't intentional deception but rather a result of punching the hole for the tooth?
Most of the more expensive heavy duty blades I've looked at have the same design in this area but the tube looks around 1/4" minimum.
Bottom line is I learned my lesson the hard way - cheaper to spend more on the heavier one now.
2012 Ford F550 Service Truck (A52377)
2012 Ford F550...
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
2016 Morbark Chipper (A55787)
2016 Morbark...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
