Box Scraper Box blade size for small tractor
   / Box blade size for small tractor #1
sroys
Hi,
This might have been covered in other posts, but I couldn't find much that would help me.
I just bought a small 13hp Ford 1300 tractor and was wondering what size box blade would be the best, or even if the tractor is powerful enough to even think of a box blade. I'm not worried about moving lots of dirt fast, but I have an area about 30'x60' that I'd like to level out, and a long gravel driveway that has a few low spots.
Thanks,
Steve
   / Box blade size for small tractor #2
4' Should be fine, if a light-duty unit...
   / Box blade size for small tractor #3
I agree.. 4' should do a good job covering the rer tires..
soundguy
So, 4' would be good. However, there's a 5' box blade on Craig's list for a decent price. Would that be too much attachment for my little 1300?
   / Box blade size for small tractor #5
I think you won't have enough traction for it..
soundguy
   / Box blade size for small tractor #6
I also think the 5 footer will be too large for your tractor. Good Luck :p
Troy
   / Box blade size for small tractor #7
I have a 5' behind my sc2400 ccyanmar and its all it really wants
I dont think your lil ford is going to pull it
Thanks for all of your sage advice. It seems that the general consensus is that I need a bigger tractor, so now all I have to do is convince my wife... :)
   / Box blade size for small tractor #9
I would not say that; I would say you need the smaller of the two box blades! Now if you are looking for an excuse to get a bigger tractor, well then.......:p
Troy
   / Box blade size for small tractor #10
i have a light weight 5'
It likes to skip over hard ground. But in softer ground or if i put some ripper shanks down i can EASLY bring my "much" larger TC33 to a standstill in no time.
2009 IC Corporation PB105 School Bus (A59230)
2009 IC...
Case IH 330 Turbo Till (A59814)
Case IH 330 Turbo...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2014 F-150 STX (A56438)
2014 F-150 STX...
