box blade size
   / box blade size #1
jerome1
Milford, Ne
none yet
I am looking at buying a John Deere 3005 and the dealer suggested a 72" box blade, is this to big for this size tractor?
   / box blade size #2
Yes - 72" is generally too big for the horsepower rating of a 3005. That said - if you plan to set the rear tire width >60 inches - you'll want one wide enough to cover your tire tracks. Then - because of the horsepower limitation - you'll just have to learn to take smaller bites
//greg//
   / box blade size #3
That tractor will pull a 6' box but it will depend on what you are doing with it as to how well. If you are just smoothing out gravel in you driveway the 6' will be great. Some serious dirt moving may present a problem. You might have to take much small bites. I would however suggest getting one that will cover your tire tracks. Measure outside to outside width of the rear tires and use that as a minimum width of the box blade.
   / box blade size #4
Woods makes a 65" unit that will work well. It depends alot on your soil.
Matt
   / box blade size #5
The Frontier 2072 specs say 27 HP minimum. I would say at 23.5 HP, you should consider a narrower box as well. Unless your rear wheels are set wider than 60" overall width, a 5 footer would probably work well with that tractor.
   / box blade size #6
I have a 1978 Kubota DT185L 18.5HP tractor with a 48" blade box. I extend the teeth fully down and have two chunks of railroad tie on the box for additional weight. Works great on hard packed gravel roads.
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
