box blade size
/ box blade size #1
jerome1
Milford, Ne
none yet
I am looking at buying a John Deere 3005 and the dealer suggested a 72" box blade, is this to big for this size tractor?
/ box blade size #2
Yes - 72" is generally too big for the horsepower rating of a 3005. That said - if you plan to set the rear tire width >60 inches - you'll want one wide enough to cover your tire tracks. Then - because of the horsepower limitation - you'll just have to learn to take smaller bites
//greg//
/ box blade size #3
That tractor will pull a 6' box but it will depend on what you are doing with it as to how well. If you are just smoothing out gravel in you driveway the 6' will be great. Some serious dirt moving may present a problem. You might have to take much small bites. I would however suggest getting one that will cover your tire tracks. Measure outside to outside width of the rear tires and use that as a minimum width of the box blade.
/ box blade size #4
Woods makes a 65" unit that will work well. It depends alot on your soil.
Matt
/ box blade size #5
The Frontier 2072 specs say 27 HP minimum. I would say at 23.5 HP, you should consider a narrower box as well. Unless your rear wheels are set wider than 60" overall width, a 5 footer would probably work well with that tractor.
/ box blade size #6
I have a 1978 Kubota DT185L 18.5HP tractor with a 48" blade box. I extend the teeth fully down and have two chunks of railroad tie on the box for additional weight. Works great on hard packed gravel roads.
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
Landa PGDC5-3500 (A64119)
Landa PGDC5-3500...
KITCHEN AID REFRIGERATOR W/DRAWER FREEZERS (A64281)
KITCHEN AID...
Challenger 236/246/248 Skid Loader Parts and Service Manuals (A63117)
Challenger...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63688)
2023 Kubota L3560...
