box blade size
/ box blade size #1
jerome1
Milford, Ne
none yet
I am looking at buying a John Deere 3005 and the dealer suggested a 72" box blade, is this to big for this size tractor?
/ box blade size #2
Yes - 72" is generally too big for the horsepower rating of a 3005. That said - if you plan to set the rear tire width >60 inches - you'll want one wide enough to cover your tire tracks. Then - because of the horsepower limitation - you'll just have to learn to take smaller bites
//greg//
/ box blade size #3
That tractor will pull a 6' box but it will depend on what you are doing with it as to how well. If you are just smoothing out gravel in you driveway the 6' will be great. Some serious dirt moving may present a problem. You might have to take much small bites. I would however suggest getting one that will cover your tire tracks. Measure outside to outside width of the rear tires and use that as a minimum width of the box blade.
/ box blade size #4
Woods makes a 65" unit that will work well. It depends alot on your soil.
Matt
/ box blade size #5
The Frontier 2072 specs say 27 HP minimum. I would say at 23.5 HP, you should consider a narrower box as well. Unless your rear wheels are set wider than 60" overall width, a 5 footer would probably work well with that tractor.
/ box blade size #6
I have a 1978 Kubota DT185L 18.5HP tractor with a 48" blade box. I extend the teeth fully down and have two chunks of railroad tie on the box for additional weight. Works great on hard packed gravel roads.
2009 Ford F-550 Versalift Signalier ATR-41 41ft. Bucket Truck (A61573)
2009 Ford F-550...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2014 INTERNATIONAL DURASTAR 4300 EXT CAB DUMP TRK (A64280)
2014 INTERNATIONAL...
2005 International 4300 Rollback (A62613)
2005 International...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
2022 EZ-GO ELITE...
