Box Blading in reverse
/ Box Blading in reverse #41
Rob,
I've watched the video you provided several times and it looks like you just adjust your links with the hydraulic lifts as you encounter tough spots???? Either way, if that kind of work hasn't resulted in any further bends, breaks, or cracks, then I'm comfortable that I'm not going to hurt anything to mine doing the work I'll be using the blade for. I learned my ramming lesson and will take it easy from now on, but wanted to add the reinforcement for that occassional rock that surfaces through the frost. Something you said in a different thread made sense to me and that was....the force that stops the tractor when pulling an implement is the same force that stops the tractor when pushing the implement. If that force doesn't break the tractor framework or housing, then it should withstand the same force going in the other direction. I thought your two videos certainly demonstrate what your tractor is capable of withstanding. I agree with everyone that has posted regarding the 3 point hitch not being designed necessarily to push with, but it sure works out for me if I can do that and now I think I can with the simple fix you suggested.
Now, if I can just make it another month without hurting myself....my wife says I can buy a welder if I don't hurt myself for 6 months and it's been 5 so far. Almost there! John
/ Box Blading in reverse #42
As others have mentioned, if you beef up all the link hardware you are then putting other hardware in jeopardy. This is of particular concern to me because the drag links (lower links) of my tractor attach to a captured pin that is held by flanges that are part of the transmission housing. If one of these flanges gets broken, you have to replace that side of the transmission housing! I don't like the design at all, but it is what it is.
I do still push with my boxblade. I'm just real careful.
/ Box Blading in reverse #43
Yup George, we all gotta be careful. In your case I don't don't blame you at all with that configuration. That could get costly or at the very least be a hard repair for the DIY guy.
John, yeah I adjust the blade using not only the 3pt but also with hydraulic side links and the top link as well. Those videos were when I was roughing in to cut a slope away. I had to go over it several times to get it reasonable. I think there are a couple times where you see the whole tractor slide kind of sideways in that 2nd video? That was fun since there is a ravine about 15' away on the low side. Best way is to drag the blade forward with the rippers down to render the soil workable and then shape or move it. I only showed videos of the backwards bulldozing since that is pertinent to the topic, but lol ... I do forward work too, of course.
/ Box Blading in reverse #44
Rob,
I had read your other thread and watched the progress on your road work and knew you had pulled the box blade on the more level areas. The rationale for pushing the box blade as you cut the sides of the hills made sense to me.....that would be a big tractor to go over on. I did see the tractor seem to slip sideways a little in the video, but it didn't appear to ever want to stop and I think, based on the size of your box blade, that there is significant weight being moved...even if loosened up dirt. The hydraulic side links would sure make angling the blade quick and painless. I mentioned before, the two grapples on the front bucket are very cool.....I take it they can be operated independently?
I attached a picture of my new 5 foot blade. I know it's not special, but it's new and new things are fun. It is already much dirtier than when I took the picture. It's proving to be much better suited for my sized tractor....what a difference 1 foot less blade makes! John
/ Box Blading in reverse #45
Dyer said:
deputyrpa,
Sorry to hear about the snapped lift arm....how much will that be for a repair (or do you have to replace it) cost? I'm feeling better about this all the time....if you and 3RRL aren't seeing significant issues with the use you both are getting from much larger implement use with much more power behind it than I will ever use, then I think I will never see issues with how I use my blade. Your box blade reinforcements look like they will hold now? Thanks! Dyer, retired
Actually, I'm glad that's what broke. The box blade is a PITA to repair! The 6' box blade is quite large for the Jinma 284, and when I got it, did not expect the tractor to overpower it so much - I expected the opposite.
Just to explain the operation, I had the box blade tilted way back and was pushing out a half-buried 1-ton boulder in low range. It just went BANG and the lift arm snapped. However, I was using the implement in a manner for which it was not designed, basically forcing it down against the boulder. I have 2 sets of arms, 20" and 24", and the 24 broke - too much leverage with the long arms and agressive tilt. The fix was easy- a weld job.
As far as ramming - when you gotta get the nurse to work, you gotta get the nurse out of the woods! I have a driveway thru the woods and wetland, and get pinched in heavy snow. When I have to move frozen piles, I can only go one way, and that's outwards.
The real issue, though, is that I was under-tractored when I bought the farm, and it took a while to be able to buy a more appropriate machine and implements. Friday, I took delivery of a DK45S TLB, and now have the correct tools for the jobs. Now that I have much more power and weight with the Kioti, all the Jinma tractor stunts are history. That being said, I will still push with the box blade, albeit in a more subdued manner.
/ Box Blading in reverse #46
Congratulations on the new Tractor! Sounds like the right tractor for the right job. I did some ground work with the new blade, but nothing in reverse...still a little apprehensive. I'll wait for snow and start pushing it again, but as you say...in a more subdued manner. I'm in no hurry to start pushing snow either, ha! Summer hits tomorrow officially. John
/ Box Blading in reverse #47
Hey Marc, that DK45 is a lot of tractor from what I've seen. You can get some serious tractor work done with that baby! They have some excellent features compared to our Spartan like Chinese tractors. But hey, they work too.
John, that Woods blade is very well built. Now see, that's an implement I don't have, so you are one up on me already. I've used my boxblade for just about everything I've done, hence I have a lot of hours and practice on it. About a year after I got it, I managed to beef it up and improve it in This Old Thread. Don't know if you ever saw that or not, but I soon realized I need to do something to it?
You were also asking about the dual bucket grapples I have on the tractor. HERE is a thread with some pictures I shared showing many uses of it. They are hooked up in parallel so they operate independently like you suspected. I use them whenever I boxblade since there's always dirt, boulders or logs to move.
/ Box Blading in reverse #48
Thanks guys. Yeah, the DK45 is a powerhouse - not that the Jinma is a slouch - but, weight rules. I definitely got my money out of the Jinma, and it's all set up for the next owner. :D The implement I really needed to get was a backhoe, and I've done lots of work so far.....24 hours in less than a week!
/ Box Blading in reverse #49
Well, I may be a bit late to add comments, but here goes...
As some of you might remember I am in the middle of building a house in the mountains of W NC. Now to some of you these mountains are really mole hills..
But-- I too have been pushing the BB in reverse.
A couple of notes:
1. I have bent the support arms on the BB
2. There are lots of rocks- See my pic here for one of the medium - large ones..
http://www.tractorbynet.com/forums/attachments/kubota-owning-operating/105088d1214089823-la463-sheared-loader-bolt-img00087.jpg
3. I have a light weight BB, thought was to buy a cheaper one, learn the ins and outs, abuse it, break it, destroy it, and if it holds up great- if not hey I honey I need a welder.. or hey honey I need a newer heavier BB....
4. The BB being lighter also means that the metal on it will bend easier than on the 3 pt lower arms... Or so goes my theory-- And fact-- SO FAR...
When I push in reverse:
1. A hand is kept on the control handle- up and down as needed.
2. If the tires are spinning lift, do not lock the differential.
3. If there is alot of push back, flip the tractor around and "bucket load" and start over with the blade.. - Hard lesson here- 30% bend on both BB pin arms..
So far it has been okay- And the welder is real close to being purchased...
I have dropped a 20 by 30 foot slope about 3 feet in elevation between the blade and the FEL, and done a ton of leveling..
Just gotta be careful!
Later,
J
/ Box Blading in reverse #50
RadarTech,
Not too late for comments and I like your approach to getting a welder. I've gone at it from the opposite end, saying, "If I had a welder, I could reinforce things, so I wouldn't break them in the first place." The response I get is, "You'll burn the house down." She's softened some to the idea lately though.
I think you went into your project having considered all the potentials involved and weren't surprised by what you found. I think your comment, "Just gotta be careful," is a good approach. Dyer, retired
/ Box Blading in reverse #51
Dyer said:
RadarTech,
Dyer-- Thanks for the compliment..
Also I attached another shot of a nice big rock..
This is one I "found" by pushing back, when the blade rode up, for 5 feet I knew something was wrong!
I turned around, attacked it from the side and after a few minutes pulled this one out..
Of course it sat there for a week before I went back to move it and take these pictures..
It is amazing how much you can move with this little tractor!!!
Later,
Jim
/ Box Blading in reverse #52
Later,
Jim
Retracting my previous content. For some reason I thought it was a BX24. Probably 'cause I was so busy looking at the rock, not the tractor. Or maybe 'cause you said "little tractor". Or maybe 'cause my new toy is a BX24 and I'm having so much fun moving rocks and doing other projects with it.
/ Box Blading in reverse #53
slewisma said:
It is amazing but what you can and what you should do with that little tractor aren't the same thing. Hard to tell from the photo but guessing at size and type of rock that thing is likely well beyond the rated lift capacity of the FEL. Picture looks great nonetheless but be careful not to hurt that little tractor or yourself!
I'm getting embarrassed with all this talk about "little tractors," ha! My BX1800 is probably equal to what the lift capacity on RadarTech's L3400 is? I would describe my tractor as a "little tractor," but it does an awful lot of work for me.
RadarTech, I don't have a FEL (some day I'll have the works,) but if the lift capacity on your bucket is 1000 lbs. (not sure if that's close, but using as an example) and you try to lift 1500 lbs., presuming that you've got enough counter weight on the back of the tractor....what would happen. Would the hydraulics just not be capable of lifting that weight? I imagine there is a tolerance given with these capacity ratings, but thought that if the rock was in the bucket and off the ground, your system must be capable of lifting it? That picture sure does look like a lot of rock.....are you able to make use of the rocks you remove as part of any landscaping? Dyer, retired
/ Box Blading in reverse #54
Right John,
If the weight attempted to be lifted exceeds the fel capacity, the system bypasses through a pressure relief valve and does not lift it. Loaders are generally matched up to the tractor's capacity, so if the loader lifts it, the tractor should handle it.
Nevertheless, always be careful with a big load like that.
/ Box Blading in reverse #55
3RRL said:
Right John,
Rob,
That makes sense....thanks. It is amazing the amount of work the loaders and backhoes will do, even on the smaller tractors. I think you appreciate the loader more when you've been working with a pitchfork on a brush/dirt pile for two weeks with very little noticable progress.....then the neighbor comes over with the new MF 2310 and within 3 minutes has the pile moved, leveled, and looking like it was never there. John
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63118)
2023 Takeuchi TL6R...
1984 John Deere 750 Utility Tractor (A63116)
1984 John Deere...
INOP/NON-RUNNING 2005 JCB Telehandler Lift (A61166)
INOP/NON-RUNNING...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
