zeuspaul,
I think John Bud gave some great instructions on popping out boulders. That is exactly what I do with great success an no damage from that whatsoever. As stated here, the lower drag links were designed to drag your boxblade. However, if they are strong enough, using the boxblade in reverse as a bulldozer is a tremendous tool in shaping, tilting and contouring an area or say a road.
I have done quite a bit of road and trail building on my rural property as shown in this link.
Pushing in New Roads and Trails
Explained in detail is the technique I use both pulling and dozing with the box blade. I suffered bent drag links too, but reinforced them quite a lot as shown in the link. And my drag links are huge as they were. I beat the crap out of my stuff pushing out 1,000lb boulders.
3RRL, do you mean real sharp turns or any turns? I leave everything down and do gradual turns and medium turns all the time....no all the way stand on one brake turns though. (from JohnBud)
John,
I'm not sure gradual turns would be too bad, but I found not having the scarifiers facing straight forward can bend them. So if it was me, I would just lift the box up and avoid accidentally catching them on something during a turn. Here's what happened to me. I was cutting a gutter with the boxblade severely tilted and I had a couple of the rippers down to aid in the groove I wanted to cut.
In that position, the side that is down is actually back away from the tractor more the the up end. Not much, but enough to see the boxblade is then not square with the tractor. I think it has to do with the geometry of the link attachments that causes it. Anyway, after cutting a while I noticed those 2 shanks were bent to the side. I hit several rocks and hard spots, but that is not unusual for my ground. I bent the shanks pretty easily. I replace the shanks and promptly bent them again doing the same thing. Finally, I think it was Bird here on TBN told me not to have the shanks down when turning or when the box is not pulling square to the tractor's direction. He was right.
The damaged shanks were not just from tilting it either. They are a result of the millions of boulders I ran into with my 55hp Kama. There were times the 7,500lb tractor was stopped dead and others that it just straightened them out or popped them off. Since then, I did a beef up/improvement job on my boxblade. One of the most important ones was to add supports for the scarifiers. I used 5/8" thick steel welding up "supports". I have not had one single shank break since that improvement, even doing the road work in the thread above.
