arizona98tj
Do you render lard? Looks like it has a good layer there.
Are you using all bought feed or feed and whatever from the garden.
I hope to be able to raise a hog or two myself this next year.
Set amount each morning. I watch the feed trough.....if they haven't cleaned up from the previous morning, cut it back a little.....if licked clean, add a little more. Here at the end, was feeding about 3 gallons (dry measure) a day between the two.
I'm feeding 50 lbs every two days, and mine are about 50 lbs smaller than yours. They do clean it up though, and if I feed less start looking for more.
Our Duroc crosses always POPPED at about 50 pounds,going from 50 to 100 in what seemed like a week. Our Duroc sow was one of the sweetest, most docile pigs we had. She punctured a back leg on something in a wallow at about 700 pounds and got an infection in the bone that we couldn't clear up. She wasn't able to bear weight on that leg and was essentially immobile so we had to euthanize her, it was a sad day as our breeders are more like pets.
Try getting your fat to almost frozen and running it through the meat grinder before rendering it. I found this to allow it to render faster and more completely but, you don't get the larger cracklins this way. I would load my fat into a cast iron Dutch oven and put it into the oven at 215F, this was just hot enough to boil out any water but not hit enough to burn the lard. I'd ladle the lard out hourly and add more fat. I liked to filter my lard through 5 or 6 layers of cheese cloth, my leaf lard would come out pure white and odorless.
