Bradco BH on Kubota
   / Bradco BH on Kubota
jpm,
How many HP is your machine? That's a big hoe.... /forums/images/graemlins/smile.gif You should update your profile and specifically put "Bradco 511" in your list of implements. Not many people have one.
BTW: I spend the first few years of my life on LI....South Shore around Bayport/Blue Point, then my family moved to S. Vermont (Manchester/Dorset). I'm right around Killington now.
That is not likely a 509 and I'd think that is a 3pt hitch model without a subframe, bucket, or freight. /forums/images/graemlins/grin.gif The buckets are seperate and run around $500.
   / Bradco BH on Kubota #14
jim it's on a mehindra 4110 41 hp i'm in islip on LI and townshend in vt
J
For some reason I was under the impression that the Grand Ls had a implement hydraulic flow rate of 9.5 GPM. I was wrong, it's only 8.3! Now the Bradco 509 calls for a min of 9.0 and max of 15gpm. I just don't know if a L3830 is capable of handling a 509 long term. Any thoughts?
   / Bradco BH on Kubota #16
You can get a PTO pump instead of running off tractor remotes. The BH uses very little power.
I run mine off the tractor and the engine doesn't know the BH is doing anything. The Woods PTO pump was 9 GPM if I remember correctly.
Multiple (3)functions at once are slow as in the case of swing, dipper and curl to dump a load. Single functions are fast and dual functions are fine when digging.
I would go with the upper end GPM PTO pump. That way you can throttle down from PTO speed. 15 GPM at PTO speed would probably make the hoe jerky.
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
23222 (A50323)
23222 (A50323)
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
Yanmar YM226 2wd tractor (A53473)
Yanmar YM226 2wd...
