Bradco Question
   / Bradco Question #11
Mark,
I inderstand when you said it might be a little slow becuse of GPM flow. These in fact are not 580 K's with extenda-hoes. We don't want to abuse and overload our rigs yet have one up from the 3 point type. I've seen the Bradco on several makes and the key issue was the salesman involved admitted these were logical over the OEM model. Unless a couple of holes per year were all you were after.
What the L35 has, makes it a good choice if you don't plant seeds. /w3tcompact/icons/wink.gif
"What is a weed? A plant whose virtues have not yet been discovered."
Ralph Waldo Emerson (1803-1882)
   / Bradco Question #12
Mark, do you know if a 2710 would have enough hydralics to power a Bradco hoe. I have been wanting to get a hoe for my 2710 for about a year but am still researching and to be honest trying to find the money for one. I know that I want a subframe mount and I would really like to be able to plumb into the tractor for the hydralics. We have a 3 point trencher that has a pump that mounts on the pto and I just hate it. I don't mean to imply that all pto/pump setups are bad just the one I have and it has really put me off of those kind of deals. My dealer keeps trying to sell me a ARP hoe but it is a 3 point setup. Any opinions you might have will be appreciated.....glen
   / Bradco Question #13
Glen B. - It depends on which Bradco you have in mind. I doubt it would handle the 609 too well, but it should do fine for the 509 or 409(?). Do you have any spec sheets on these models?
Mark
   / Bradco Question #14
I will have to do some digging for some spread sheet info. I was just being lazy about this and seeing if you knew. I will do some checking and if all else fails, I will check with Bird for the spread sheet info. I bet he has it somewhere. Thanks
   / Bradco Question #15
glen b, I don't have a backhoe and don't know what kind of flow any of the Bradcos require, but the manuals for the B2710 show total capacity of 9.5 gal./min. (6.4 for the 3-point and auxilliary hydraulics and 3.1 for the power steering) if that helps you.
Bird
   / Bradco Question #16
I knew I could count on you Bird. Thanks......glen
   / Bradco Question #17
You'll also need the specs for the flow requirements of the Bradco backhoe(s) you're considering.
Mark
   / Bradco Question #18
Your welcome, Glen. Good luck with your backhoe shopping.
Bird
   / Bradco Question #19
Mark, I guess I am stuck on stupid today, but I got on the bradco web page and the only backhoes I can find anything about are for skid-steers. Maybe I am looking in the wrong place or something. Somedays I can make this computer do anything I want and then there are days like today. Do you have a website address or anything that might steer me in the right direction? glen
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
