Brand 5220ch overheated
   / Brand 5220ch overheated
Branson wanted the purchasing dealer to pickup ,and go over the machine give me peace of mind everything’s. I told them why would I want the dealer who forgot the refill the antifreeze to go over the machine again when it should of been done the first time. I left it at ,I’ll run the machine for the first 50 hours, and if there is no issue I will call them and have them setup for another dealer to fully go over the machine when doing the first 50 hours service. I also confirmed all emails and phone calls are attached to the warranty files on the machine. You think this is okay or should I push to have another dealer go over the machine before the 50 hours? Other problem is I’ve been out of a machine for a few months so I need to Use it. Don’t really want it tied up for 2 weeks at the dealer. What you guys think?
   / Brand 5220ch overheated #43
Run it , You check the oil , hyd oil, water, front axle oil and you should be good till the 50 hours service at a different dealer........:thumbsup:
   / Brand 5220ch overheated #44
This but grease everything and make sure the air filter is in there as well.
Lol after the antifreeze the first thing I checked was the air filter make sure it was in there. Thanks for all the input I appreciate it
   / Brand 5220ch overheated #46
Just and FYI to maybe ease your mind OP. Years ago I assisted CHP with a pursuit in foggy weather. I knew the suspect driver would crash because of the road he was on. Sure enough he could not navigate the turn as I knew he could not and rolled his Chevy diesel pickup onto it's side. The engine idled like that for a good 30 minutes BEFORE it began to show signs of stress. It was another good 15 minutes before the engine finally seized and stopped. It was a Duramax engine. The driver has screwed up and went to the ER before getting three squares and a hot cot. LOL
So... I am sure your engine is fine. The gauge was hopefully reading higher than actual, which would be in your favor. Diesel's take quite a bite of punishment and keep on trucking. B.
2022 Freightliner M2 106 Medium Duty Rollback Truck, VIN # 1FVACXFC5NHNM7347 (A51572)
2022 Freightliner...
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2018 John Deere R4038 Sprayer (A53342)
2018 John Deere...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
