I'm searching for a new UDT filter and found a Stens brands that is the same as the Kubota one. Is Stens a good replacement or stick with the Kubota brand UDT filter?
If you use the center drain plug and don't drain the final drives it should be even less, also raise the 3pt fully and curl the bucket down etc. will reduce the amount of fluid in the trans.I spoke too soon. I check out the cardboard yesterday and there is an oil puddle. I ordered a filter and a new oil filter drain pan that will hold 4.5 gallons. I believe the transmission only hold 4 gallons, so I can drain it completely out and reuse it. I do want to inspect the oil filter housing on the engine. Is there a place that I can find a diagram for a parts breakdown so I know what to look for on the engine? I tried the Kubota website parts diagram, but it doesn't load for me.
