Rotary Cutter Brand New Land Pride RCR1242 shaking too much??
   / Brand New Land Pride RCR1242 shaking too much?? #21
Ruff thank you, good catch. i went out and looked again to check for that, they are in alignment.
Good...at least you know that is not the problem. I could not imagine mowing with your cutter the way it shakes. I hope the dealer takes care of you!
Success
This morning I dropped off the shaky one, and the dealer set up the other RCR1242 they had, he replaced and cut a new shaft too, tested the unit in front of me. I brought it home, this thing is nice and smooth! really stoked to get hoggin'!
thanks everyone for pointing me in the right direction
   / Brand New Land Pride RCR1242 shaking too much?? #23
Good deal.
i think if the shaft had been bent, the inner and outer halves would not slide smoothly onto each other. On the new smooth running one, the blades have the same 1/2" of vertical play in them, so that wasnt the problem on the old one. maybe it was the gear box or the disc
   / Brand New Land Pride RCR1242 shaking too much?? #26
Does it start up with any less shake?
Yes it does ruff. Its abrupt engagement but it’s nothing like the first one. There is no bang or twisting of the entire deck like before. Just a thud. This one operates just as I would expect. Just waiting on bxpanded under armor to show up so I can venture out into the woods
Good question. These electric PTO engagements are brutal. Even at an idle.
I agree. Why don’t they make them spin up slowly????
   / Brand New Land Pride RCR1242 shaking too much?? #30
I have the electric/hydraulic kind that you can gently engage, but I know I'd never want a machine with a straight 'on/off' engagement.
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2009 Mazda 3 Sedan (A51694)
2009 Mazda 3 Sedan...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
Informational Lot - Shipping (A53472)
Informational Lot...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52576)
2023 TAKE 3...
