Brazing, need advise to fill a ding
   / Brazing, need advise to fill a ding #11
. A reducing flame has less O2 than stoichiometric.
A slightly reducing or carburizing flame is preferred for most welding because an oxidizing flame tends to oxidize the weld material due to the high temperatures and the excess oxygen in the flame.
You are right. I was corrected in an earlier post by someone else as well.
   / Brazing, need advise to fill a ding #12
I wonder if JB weld or some other epoxy would work if it would adhere?
   / Brazing, need advise to fill a ding #13
I wouldn't worry about filling it, just dressing it down so that no sharps were cutting the seal. It's not like there will be any leakage, just whatever minute amount of fluid gets scuppered out in the crater. A bigger concern would be the possibility of rust forming in the breached chrome plating. Maybe cleaning with acetone and a stiff brush, like a trimmed back toothbrush would be sufficient for epoxy filler.
   / Brazing, need advise to fill a ding #14
Or leave the leg up so the ding is inside. No rust that way.
Jim
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A57024)
2016 KBH...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2010 Specialized Structure 1456 Tri-Axle Portable Office Trailer (A55852)
2010 Specialized...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
