Brazing, need advise to fill a ding
   / Brazing, need advise to fill a ding #11
. A reducing flame has less O2 than stoichiometric.
A slightly reducing or carburizing flame is preferred for most welding because an oxidizing flame tends to oxidize the weld material due to the high temperatures and the excess oxygen in the flame.
You are right. I was corrected in an earlier post by someone else as well.
   / Brazing, need advise to fill a ding #12
I wonder if JB weld or some other epoxy would work if it would adhere?
   / Brazing, need advise to fill a ding #13
I wouldn't worry about filling it, just dressing it down so that no sharps were cutting the seal. It's not like there will be any leakage, just whatever minute amount of fluid gets scuppered out in the crater. A bigger concern would be the possibility of rust forming in the breached chrome plating. Maybe cleaning with acetone and a stiff brush, like a trimmed back toothbrush would be sufficient for epoxy filler.
   / Brazing, need advise to fill a ding #14
Or leave the leg up so the ding is inside. No rust that way.
Jim
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
More info coming soon! (A55851)
More info coming...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2025 Electric Scooter (A55853)
2025 Electric...
2009 Toyota Highlander SUV (A55853)
2009 Toyota...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
