Breaking in my new toys... from Yeehaw! to Uh oh!
   / Breaking in my new toys... from Yeehaw! to Uh oh!
Just curious, but how do you heat the scarifer? Will an open wood fire do the job? We have a butane heater for heating up our branding irons, I might just set that sucker in there. :)
john_bud said:
Did my eyes deceive me, or did you write that someone was coming out to install the tooth bar for you? You do know that it is just 2 holes drilled in the sides of the bucket and two bolts, right? Or is yours different?
HA! I like the tone of your question there jb... cautious as if to say, "Are you THAT sorry?" without actually saying it. :D Yes, that's all it is, two holes and some bolts. I had every intention of just doing that myself, but the guy who did my FEL for me felt bad that it got delayed so long, and felt bad that they sold the bale spear they'd ordered for me to someone else, so I still don't have that yet, and felt bad that they didn't get the toothbar on the original order. So he said when the bale spear and toothbar came in he'd just send a guy out and tell them to put it on for me. He did say that they would torch the hole instead of drilling - not sure how much that matters. While never being accused of being handy, I do think I could manage that if I had to. :)
   / Breaking in my new toys... from Yeehaw! to Uh oh! #82
Torch the hole!!! OMG! It's just a 1/2" hole. I wouldn't let them torch my bucket. Then again, I have a 1/2" bit... My opinion is that torching holes is for lazy people, sloppy people, low quality work usually is the result. Now there are probably some high quality, super neat go getters that torch holes. I have not had the privilege of meeting any, yet.
Well, yes. I did read that you said you were pretty much the opposite of handy, didn't want to pick on you....
The propane torch will work. Just takes a bit longer. Normally a "rosebud" tip on an oxygen / acetylene torch is used. Lay it curve up, play the torch on the bent part until they are red hot. Pound them flat with a hand maul or sledge hammer. Something small like this, I would heat it and bend it straight in my bench vice. Let it cool slowly to keep it soft. Wire brush off the burnt paint, prime, repaint and install. You DON'T want to heat the tip of the scarifier. It is hardened steel.
jb
   / Breaking in my new toys... from Yeehaw! to Uh oh! #83
Sometime later in life I might resort to using a torch to make a half inch hole, but right now I don't even do that with a 2" hole. In fact, I had to be talked into letting my friend cut hole with a torch for a gearbox in half inch steel, as I was fixing to set it up in the mill. (I do everything the hard way). I did drill the 4 bolt pattern around his almost perfect torched hole. A drilled hole just looks better, wears better due to it fitting better, and doesn't mess up any surrounding paint. It also doesn't promote rust nearly as bad.
Buy a good drill bit, and have it ready when he gets there, and tell him you don't allow torches on your property due to insurance and fire regulations. Tell him if he has a fire watch and a million dollar fire policy, you would be happy to let him go ahead, but otherwise, here's your drill.(Fire watch is a person who carries the extinguisher and stays back while the operator is behind his cutting/welding shield)
If you have to bribe him, do it, as you will be happier with it properly done. However, watch him closely, so you will get your money's worth in schooling.
David from jax
   / Breaking in my new toys... from Yeehaw! to Uh oh! #84
One should be very, very careful teasing someone who is armed and messes with longhorn cattle :eek:! Jay :D
OK, OK, so now my manhood is basically on the line. I let the guy torch the hole and not only do I have a sloppy-looking, odd-shaped, rust-ready, paint-destroyed hole, but I'm pretty much a wuss. :eek: On second thought, I think I'll just carve the hole with my pocket knife and tighten the bolts with my teeth. :D ;) HA!
So, point well taken. I'll stop by and get a good 1/2" bit. I have a set of Dewalt bits that has a 1/2" one. Do you have to have a special bit for this type of metal. I've worked with wood, but literally never have done anything with metal. The Dewalt bit has a funky tip to it that's supposed to cut into wood really fast. Doesn't seem ideal for metals. Do I need to use oil when drilling it?
OK... what happens when you heat hardened steel in a case like this?
Ha! Yeah, just ask the cow we had a disagreement with this morning! She had a case of wonderlust, but we cured her of it, permanent-like. :D
   / Breaking in my new toys... from Yeehaw! to Uh oh! #86
Spivey, don't get a 1/2" bit for a 1/2" bolt. It'll be too tight. I'd recommend a 9/16" bit!
   / Breaking in my new toys... from Yeehaw! to Uh oh! #87
I ended up drilling pilot holes, then I used this "step drill bit" thingie, and I ended up using a 5/8'' bit and had to "egg" the holes on both sides of the bucket because I made consistent matching "perfect" measurements :eek: on both sides :rolleyes:. What is the old saying "measure twice and cut once" ;)? At least they match and they do work. I am more pleased with my "handiwork" than I am with the manufacture of NH's bolt-over the bolt-on cutting bar toothbar :(. Having said all this I really do like the utility of the toothbar :D. Jay
I'll get the bolts before I get the bit, right now I have no idea the actual dim.
jbrumberg - Sounds like we studied at the same school. I can relate to that joke, I cut it THREE times and it's STILL too short! :) I can measure something, measure it again, mark it, measure it again, cut it or drill it and it still be wrong. Generally speaking I'm not a dense guy, I have an engineering degree from Purdue - but sometimes it is beyond me how I can screw up a project. :confused: That's one thing I like about working with wood, you can kind of recover from mistakes lots of time. And if not, put up more trim it just looks fancier. :)
   / Breaking in my new toys... from Yeehaw! to Uh oh! #89
Good call.
I was gonna suggest a 17/32" but hey, this is a tractor. The step drill thing seems like a good choice too. Be sure to center punch before drilling so the drill doesn't "walk" on you.
Spiv, did you ever see this old thread about installing the toothbar? It was one of the first things I did.
INSTALL TOOTHBAR
   / Breaking in my new toys... from Yeehaw! to Uh oh! #90
I would go with the 17/32 or 33/64's rather than a 9/16, unless I didn't have them, and did have a 9/16. If your going to buy a drill, and they have the 33/64ths, that is what I would use with a second close as the 17/32".
I personally think the step drill is better suited for sheetmetal, rather than 1/4" plate, but do what you think is best. Whatever you do, go slow and use plenty of cutting oil to save the bit from heat.
David from jax
MAH QUICK ATTACH MAST W/ 48" FORKS (A51242)
MAH QUICK ATTACH...
John Deere 643 Corn Head (A50514)
John Deere 643...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2008 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2008 CATERPILLAR...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
UNUSED FUTURE SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED FUTURE SKID...
