broken 231
   / broken 231 #1
larry dun
mena,ar
231 massey ferguson
Afternoon everyone, I farm a little and use a small Massey Ferguson tractor for keeping deer food plots clipped and it sets most of the time it is a 1999 model and has 125 hrs so you can tell it is about wore out. Having a little trouble with the injector pump I assume, can't get fuel to the injectors so I thought I might get a little info or suggestions. Thanks
   / broken 231 #2
G'day Mate and welcome to TBN from Downunder.
I suspect that Catherine will be along soon enough to shift your question over to the MF forum, where you'll receive plenty of helpful advice.
In the meantime, enjoy the site... you can also check out the 'Similar Threads' at the bottom of this page.
   / broken 231 #3
Why do you think it is the injector pumps?
Have you used the manual primer pump found on the right hand side of the engine block?
Did you recently change the fuel filter or run out of diesel?
   / broken 231 #4
Welcome to the forum.
:welcome:
As Wagtail already mentioned, I'll be moving your thread over to the MF section to see if someone over there knows. I hope you find your answer!
2020 John Deere R4023 Sprayer (A53342)
2020 John Deere...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
2021 John Deere C12R Corn Head (A53342)
2021 John Deere...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2024 Greatbear Forklift Jib (A51573)
2024 Greatbear...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
