broken 231
   / broken 231 #1
larry dun
mena,ar
231 massey ferguson
Afternoon everyone, I farm a little and use a small Massey Ferguson tractor for keeping deer food plots clipped and it sets most of the time it is a 1999 model and has 125 hrs so you can tell it is about wore out. Having a little trouble with the injector pump I assume, can't get fuel to the injectors so I thought I might get a little info or suggestions. Thanks
   / broken 231 #2
G'day Mate and welcome to TBN from Downunder.
I suspect that Catherine will be along soon enough to shift your question over to the MF forum, where you'll receive plenty of helpful advice.
In the meantime, enjoy the site... you can also check out the 'Similar Threads' at the bottom of this page.
   / broken 231 #3
Why do you think it is the injector pumps?
Have you used the manual primer pump found on the right hand side of the engine block?
Did you recently change the fuel filter or run out of diesel?
   / broken 231 #4
Welcome to the forum.
:welcome:
As Wagtail already mentioned, I'll be moving your thread over to the MF section to see if someone over there knows. I hope you find your answer!
2013 Husqvarna LGT2654 54in Riding Mower (A55853)
2013 Husqvarna...
2017 Kubota M7-151 Premium MFWD Tractor (A55315)
2017 Kubota M7-151...
UNUSED FUTURE X-HWG72-72" HYD WOOD GRABBER (A57193)
UNUSED FUTURE...
WOODS 1033674 SUBFRAME KIT (A57192)
WOODS 1033674...
14179 (A55788)
14179 (A55788)
2019 Dodge Grand Caravan SXT Van (A55853)
2019 Dodge Grand...
