Broken Bolt Extraction
   / Broken Bolt Extraction #12
It all depends on how jammed in the remaining stud is. I've had some that I had to essentially hollow out with successively larger drills until I finally peeled the remaining thread out of the hole.
In your case, I think the left hand drill trick would get it. HF sells 'em pretty cheap.
   / Broken Bolt Extraction #13
Lastly, there are special (read expensive) welding rods that ill only stick to the broken bolt and not the bore. This allows you to build up the broken bolt so you can weld a nut on at the surface. This would be a absolute last resort.
Good luck.
The heat from welding will shrink the bolt loosining it up to where it screws right out.
   / Broken Bolt Extraction #15
G'day Mike a left handed drill is one one that drills in the other direction i.e the flutes of the drill run opposite to the norm they are very handy as you know when a drill 'bites' they can unwind the broken bolt, they are not a drill you use in your left hand:D
Jon
   / Broken Bolt Extraction #17
If you really need a left hand bit and no place to buy one you can make your own if you know how to sharpen a drill bit by hand. Take a regular RH bit and cut off the shank, re point the end that once was the shank. It will have a wider than normal chisel point so the web will need thinned. I've done it before and it really works, but I've also sharpened a gazillion drill bits by hand which made it a bit easier. The bit won't have a nice solid round shank for the chuck, so beware.
If anyone cares, lh drill bit got 1 bolt out no problem. The others were removed with my square extractor thing. It was really easy, not sure why I thought it was going to be so hard to do....
   / Broken Bolt Extraction #19
the welding rods in question are called extraction rods.
   / Broken Bolt Extraction #20
He11 yeah we care! Congrats! Always something to learn in a thread like this! For example, "My left-handed neighbor with his cordless, is not my solution to broken off studs!" :D
2025 J and C 6X12SA 12ft S/A Enclosed Trailer (A56859)
2025 J and C...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
Ladder Rack (A57454)
2018 KAUFMAN 44 FT CAR CARRIER TRAILER (A59575)
2018 KAUFMAN 44 FT...
