Broken Rear Window replacement
/ Broken Rear Window replacement #1
manzer7
Frenchville, Maine
John Deere 1025R
I broke my rear window on my 1025R 2018 JD Tractor a few weeks ago.
I got a new window for $1,263.81 and put it in myself - no problem.
BUT, I will not buy another one if I unfortunately do it again. I saved the old parts and put it all together again with 1/4 inch plywood and plexiglass.
I hope that it will be just a spare part for if I do break it again. Here are some pics . . . . . . . (Also the tool I made to screw (or hold) the inside nut part.)
Most handy tractor - I had my rake in the ballast box and forgot that it was there when I raised it while the rear window was open !!!!! Oooops ! Expensive rake !!
/ Broken Rear Window replacement #2
my brother in law raised his vertical splitter into the rear glass and managed to bend the hinges without breaking the glass. he got lucky. did you experiment with how big a cutout you can get away with while keeping enough structural integrity. seems like a big difference in visibility.
/ Broken Rear Window replacement #3
Man I thought the rear glass on my Kubota l6060 it was pricey at $450. That's a ridiculous price
/ Broken Rear Window replacement #5
Is that a flat glass panel? It is quite likely a local glass shop could make you a piece of either tempered glass or laminated glass for a lot less.
/ Broken Rear Window replacement #7
If you make one use UV resistant PolyCarbonate, aka Lexan or Tuffak. Much stronger stuff, far more scratch resistant.
/ Broken Rear Window replacement #8
Such a cute little tractor!!!
/ Broken Rear Window replacement #10
Ouch that's expensive, I would love a cab, but the glass wouldn't survive!
Sent from my SM-S921U using TractorByNet mobile app
/ Broken Rear Window replacement #12
I think I would take good look a Lexan IF there's a next time.
/ Broken Rear Window replacement #13
I'm a dummy and got lucky too. I had my Dad's rear blade on my L3540HST and picked it up high. It had a crank at the top to change the blade angle. It had pressure on the rear window when I realized what happened, but didn't break.
I took my angle grinder and cut the sucker off. It was rusted and wouldn't work anyways.
2022 EZ-GO ELITE...
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
2012 Mini Cooper Hatchback (A64557)
2012 Mini Cooper...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
