brush blades on finish mower
   / brush blades on finish mower #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I am needing to keep about 10 acres of field mowed. I will only be doing this several times a year so doing something like changing blades wont be a problem. So is it possible to put brush hog blades on a finish mower deck? I am not trying mulch down three inch saplings, just keep a field mowed. I was just thinking of saving the finish blades for doing the lawn around the house and the brush blades for the field. Any thoughts?
Eric
   / brush blades on finish mower #2
If it's just a field w/ grass, weeds etc.. mowing the field won't hurt your blades. Get a second set of finish blades if you'd want to switch them out.
   / brush blades on finish mower #3
Eric_Phillips,
You could try these, get your checkbook ready though!
<font color="teal">Meg-Mo</font>
Personally, I'd just mow the property twice, first at the highest setting, then with a finish cut. Just do it often enough to keep it groomed.
More seat time.
   / brush blades on finish mower #4
Probably not many 'choices' for blades for your rfm. Which one is it?
   / brush blades on finish mower #5
Naaah, won't work. Much different setup.
Even if you could cobble up something to fit, the belts would not like starting a big heavy blade.
   / brush blades on finish mower #6
Sounds like you just want to maintain the 10 acres, not turn it into lawn. I would buy an inexpensive light duty rotary cutter. Then if you let it go for several weeks before mowing, or want to cut some brush, then no problem. 10 acres several times a year would add a lot of wear on your expensive finish mower. And unexpected things that could damage your mower love to hide in taller grass.
   / brush blades on finish mower #7
In the event you are still shopping, I keep about 10 acres at "semi lawn quality" using a Woods RM-990 finish mower. It has three spindles, each with 2 heavy swing-back blades. The mower and blades are rugged enough to cut brush without difficulty but they do a nice smooth job on grass too. There's a review here .
I think the current price is arount $3500. Pricey, but built like a tank to last a long time.
   / brush blades on finish mower #8
Have Blue is right, they are totally different. The rc has a spindle pan to which two massive "meat cleaver" like blades are attached by pivot pins. The high mass builds up tremendous inertia which simply breaks whatever the blades hit. It they hit a stump or imbedded rock, the blade can slide off at an angle and then whiplash back into position without any loss of rpm. No way you can hybridize this with a finish mower.
Hobbyfarm's idea of two passes is a good idea. BB TX (Bill)'s suggestion of just getting a light duty rotary cutter is a good one too.
   / brush blades on finish mower #10
Eric's original question was whether he could take a standard RFM with a straight blade, use it for cutting lawn, then change the blade for a spindle pan with free pivoting blades when it was time to cut the hayfield. My answer to him was, "No, you cannot simply take the straight blade off a standard RFM and stick on a RC blade and make your own hybrid." He wants something like that vehicle that changes back and forth from SUV to pickup truck. The Woods RM990 seems like a great compromise, but my point is that you cannot change blade types back and forth.
I like this model. It will meet the needs of people who cannot afford a finish mower and a rough cutter (although I think most people who can afford a tractor with enough hp to drive this thing could afford 2 cutters). A disadvantage I would see is that weed seeds picked up while cutting in the rough could be dropped into the lawn unless you power washed the underside after each use in the rough. It's also very wide to maneuver between trees and shrubs in the lawn.
2010 Ford Crown Victoria (A51694)
2010 Ford Crown...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
Adams 5 T Spreader (A53472)
Adams 5 T Spreader...
UNUSED AGT LRT23 STAND ON SKID STEER (A51247)
UNUSED AGT LRT23...
