Brush cutters
   / Brush cutters #1
Slickheadhunter
Weare, NH
Mahindra 4025 4wd
I have never used a brush cutter, so I'm looking for recommendations on what weight cutter a Mahindra 4025 can handle easily. I'm looking for the heaviest 60in cutter I can use comfortably on this tractor. The tractor is over 6000lbs with the loader and loaded tires with a three point hitch rated at 3525 at the lift points. It's rated at 31 PTO with 41 engine hp.
   / Brush cutters #2
The major manufacturers (Woods, Landpride, Bush Hog, etc.) have heavy-duty cutter lines, along with light- and medium-duty lines. I don't think you can go wrong with any of the heavy-duty models. The manufacturers' Web sites will list recommended PTO HP ranges for their various models.
Steve
   / Brush cutters #3
Your manual should tell what weight brush cutter you can use. Three point capacity and mower weight is not one in the same. At least not on my tractor.
   / Brush cutters #4
If your looking for a true heavy duty cutter, I think you'll find that it may be a bit of a workout for your tractor to get it spinning. If I were you, I would look at the true medium duty cutters like the Bush Hog BH25, the Brown 415, the Woods BB600, and so on.
I think you could handle the weight of the heavy duty cutter (not sure from experience) but I know that 31hp is very low for a truly heavy duty rotary cutter. What size brush/saplings/trees are you planning on mowing? Your on the right track by staying away from the light duty cutters. :thumbsup:
If you have some time, google the specs on the truly heavy duty cutters, the Woods 6000, Bush Hog 405 etc. I don't believe Brown makes a 5' HD cutter.
   / Brush cutters
I ordered the tractor a couple weeks ago, so no manual yet. My 2516 manual doesn't say anything about which size attachments to use, just how to use the three point hitch. I would like to use the heaviest cutter it will comfortable handle, I'm just not sure what that weight would be sticking 6ft or so back behind the tractor. It will be used primarily for my clover food plots, I also have some areas over run with sumac so every couple years only.
   / Brush cutters
The BB600X I think is woods medium duty cutter and weighs just over 1000lbs. I'm guessing this size and weight might be all I would need. I believe 31PTO should handle this size cutter without any trouble, just using common sense because like I said I have no experience with a brush hog at all.
   / Brush cutters #7
BH25 weighs 905 lbs and they claim to have a minimum horsepower rating of 35 pto gear box is 130hp The only concern I could see would be getting it spooled up might be hard on the pto clutch if the engine cant get it turning from an idle. I have a BH27 its built well.
What ever you get I would recommend the chains for guards I've seen a lot of the rubber ones worn out
   / Brush cutters #8
No doubt it will pick the cutters up easily. For me the concern is transporting. A cutter too heavy lifted might break something on the three point bouncing up and down while transporting it. If your manual doesn't say anything about what size attachments to use it sounds like you have a blank check as far as your warranty and the size of the attachment you pick.
   / Brush cutters
I definitely don't want to break anything, perhaps a cutter in the 600 or 700lb range might be a better option. I think woods minimum PTO hp for the BB600X was 30, cutting it kinda close I guess. I'll try sending Mahindra an email and see what they recommend.
   / Brush cutters
I checked again on the woods web site and it lists the hp in engine hp? I didn't see recommended PTO hp.
Working width 60"
Transport width 65.5"
Overall length 104"
Deck length 70"
Cutting height 1" to 9"
Approximate weight 604 lbs
Tractor Engine HP 25 - 50 hp
Tractor PTO speed 540 rpm
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
New Holland C238 Compact Track Loader Skid Steer (A52377)
New Holland C238...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
MURRAY 22" 2N1 SELF PROPELLED GAS PUSH MOWER (A51248)
MURRAY 22" 2N1...
