brush from ice storm
   / brush from ice storm #11
This tool will be the envy of the neighborhood, you'll clear the brush in no time at all with a pair of these... No chains, not getting off the tractor time and time again... Just grab and move trees, logs and brush to the burn pile. Plus you leave all the dirt behind. Its also a real nice back aid - you can saw logs and limbs standing up and it takes the pressure off branches so the chain saw doesn't bind up. See more at Front-End Loaders by Westendorf: loader for tractor, shade canopy, wagons, manure & landscaping equipment. Smallest unit starts at around $800 for set of two.
seem kind of westendorf specific with no details on how to attach. will this work with my b3030 w/ the quick attach option? let me know
   / brush from ice storm #13
We have fit quite a few Kubota loaders, which model loader do you have? Currently we fit the 2710, BF-500, LA-302, 402, 480, 513, 680, 723, 950 and 1251. We fit new models all the time, we'll just need a few dimensions. If you have the skid steer adapter on your loader, the BC-7700 model is the version for you.
   / brush from ice storm #14
Well our best method is very low cost. Get yourself some Blue poly tarps and pile on the brush and jsut hand drag it to the burn pile. We jsut did a massive pruning for 2 years of 1,400 olive trees and that is hwo we did it. Use a good lopers to lop off the branches. Anything lopped you throw on the tarp and hand drag to a burn pile. If the branch is to big for the lopers it stays on the limb. We ahve a littly 3PH carryall/cart and my hubby throws the wood in there and takes it to the wood pile. As he ahs time he attacks the woodpile and cuts it down to fireplace size.
Actually brush is not all that heavy to drag on a tarp and plus it is actually good excercize. I fill the tarps and drag and my husband mans the fire. I am afraid of the fire so this works best for us. It is possible to move acers and acers of brush on a tarp, beleive me I ahve doen it and it really isn't allt hat bad. Just takes effort is all. Then if you can believe it I hand rake everything to get up all the small sticks. We lay down nets for harvsting the olvies and the small sticks wreck the nets. Teh ahrdest part is just to start. Ideal is to have 2 or more people working as a team, makes the work more pleasent.
   / brush from ice storm #15
How about fitting other brand loaders such as a JD148. The idea of no extra outlets or valves/hoses is very appealing
   / brush from ice storm #16
Yes, we fit the 148 loader. The larger BC-5000 is the recommended unit. Front-End Loaders by Westendorf: loader for tractor, shade canopy, wagons, manure & landscaping equipment. This unit is quick attach and the female adapter is built into the BC-5000. You will need the male couplers for the end of your loader arms. This 5000 unit is heavier than the 3000 and 4000 units which don't require quick attach. The built-in adapter strengthens the attachment for use on the larger loaders and allows quick change between bucket and grapple without having to get off the tractor to lock them in place.
   / brush from ice storm #17
That is one of those "why didn't I think of that" things. I may try that tomorrow here. I'm sure the tarp would slide easily on the snow, but I'm not sure about wading through it pulling the tarp. First trip has to be the hardest, right? :) I have some trimming to do, and still am without a tractor.
   / brush from ice storm #18
We didn't get your ice storm but got slammed pretty hard on the west coast last week. Most of our "damage" was a lot of wind blown branches; mostly small and fairly light stuff. For this type of clean up (after the snow is gone) I'll use my 2cuyd bucket. This is a high volume/light load plywood "bolt-on" bucket. Pretty easy and inexpensive to build. Less than $100 if you buy all materials and less than one day to build.
I posted building it here: http://www.tractorbynet.com/forums/build-yourself/112403-2cuyd-leaf-bucket-scut-works.html
And using it for fall leaf gathering here: http://www.tractorbynet.com/forums/kubota-owning-operating/112402-big-bucket-leaf-moving.html
If you have a lot of long branches to move (and don't have forks), for a "quick fix tool" I'd consider just "C" clamping a couple of 2x6 "forks" onto the FEL ("sandwich" the bucket bottom w/2-2x6's, long-reach "C" clap in front and maybe drill/bolt in back---or---just bolt a couple of 2x6 "forks" to the FEL bucket sides).
well clean up is done, I found that my 7" long teeth on my tooth bar worked great. I was able to do some hauling but mostly was able to roll the brush to the pile. This had kind of a broom effect on the way and did a great job of cleaning up. I think a graple would be the best thing for this job as it would speed things up so sometime soon I may purchase one.
have a good one all
   / brush from ice storm #20
What kind of price range is the BC-7700 in.
2007 Sterling L7500 Terex Commander C6060 60ft Insulated Derrick Digger Truck (A55973)
2007 Sterling...
JOHN DEERE 650 TRACTOR (A52708)
JOHN DEERE 650...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2022 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2022 Caterpillar...
2010 GMC Acadia SL SUV (A56859)
2010 GMC Acadia SL...
VINTAGE JOHNSON OUTBOARD MOTOR (A58374)
VINTAGE JOHNSON...
