Brush hog gearbox...oil or grease?
   / Brush hog gearbox...oil or grease? #41
grease alone wil cavitate unless a 0 or 00#.. #2 or #4, the common gun greases are not suitable for gear boxes.
I have in a pinch used them with a 25/75 mixeof gear oil to make a soupy that slumps if I can't lay hands on a 0# grease..
soundguy
   / Brush hog gearbox...oil or grease? #42
Are the seals that hard to change? Never had to do one.....
Depends, I have done a few. Some you can take off the stump jumper with a wrench on the nut. Some require a 3/4 impact and a torch to heat the nut they can be very stubborn depending on age.
2015 Volkswagen Jetta Sedan (A50324)
2015 Volkswagen...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A50322)
2018 Toro Z-Master...
1982 LeeBoy Motor Grader (A52748)
1982 LeeBoy Motor...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
Kivel 3500 Lb Pallet Forks (A50121)
Kivel 3500 Lb...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52141)
2018 FREIGHTLINER...
