Brush Hog Lube
   / Brush Hog Lube #11
I had a 4' 951 but not anymore.
You can either tilt it over and let it drain ( use boom pole or FEL ) Or you can use a battery water suction buld to suck the oil out... or similar device.
That 951 is a superior machine. i ran 85/140 lube in mine.
Soundguy
   / Brush Hog Lube
Right now I don't have any means to drain the existing lube. Do some people just top it off every so often and call it good? Could I get by with this for awhile until I have a means to drain it?
   / Brush Hog Lube #13
As long as it does not look contaminated.. I'd just top off and go.
Water contamination will show up as an emulsion.. like a milky look.
Dirt contamination would be obvious.
Run a clean rod it there and draw it out and look at the oil. If it looks like 'good' clean oil.. fill to the correct level and go.
soundguy
2005 CHEVROLET SILVERADO (A53843)
2005 CHEVROLET...
1980 TIGER TA KILL TRAILER (A53843)
1980 TIGER TA KILL...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
2013 Buick Enclave SUV (A51694)
2013 Buick Enclave...
1266 (A50490)
1266 (A50490)
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
