brush hogging - how high is too high?
   / brush hogging - how high is too high? #21
For brush, grass, stemmy weeds, and green stuff.. not to excede 2" or 1" woody stuff.. You can pretty much mow anything you can get your front axle over, and keep pto rpms at 540.
When I bought my pasture it was 7' of ragweed, and dog fennel, with an underlayer of briar. My 33hp NH 1920 and 5' KK mower ate it up in 2nd range, 2nd gear... engine never bogged down.
Soundguy
   / brush hogging - how high is too high? #22
I've mowed down some pretty big saplings and my mower can handle anything my loader/tractor can knock down ...but, once cut down, some saplings fight back! Had one come up through the radiator ...an expensive lesson ...think "skid plate"
   / brush hogging - how high is too high? #23
Premature wear of the PTO shaft U-joints could be the least of your problems...
What could be some of the other problems <font color="red"> ? </font>
   / brush hogging - how high is too high? #24
</font><font color="blue" class="small">( Premature wear of the PTO shaft U-joints could be the least of your problems...
What could be some of the other problems <font color="red"> ? </font> )</font>
Running a mower or cutter off the ground could result in the blades throwing debris that the side skirts (of the mower or cutter) should capture. This could be lethal if debris hit the tractor operator. Or, a blade could come off...
   / brush hogging - how high is too high? #25
Plus lifting the cutter completely off the ground puts a lot of stress on the lower 3ph arms, particularly when you go over bumps that cause the cutter to 'bounce'.
CFG Industrial MH12RX (A53316)
CFG Industrial...
19015 (A55788)
19015 (A55788)
46'x25' Metal Garage (A53316)
46'x25' Metal...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
CAT 259D Skid Steer (A53314)
CAT 259D Skid...
