Bucket Mounted Push Bar?
/ Bucket Mounted Push Bar? #1
DENALIAKITAS
Is there anyone out there that makes a bucket mounted push bar? Something that would work for pushing around non running vehicles etc. Or has anyone made something up for themselves? Thanks
/ Bucket Mounted Push Bar? #2
I placed a tire between the loader and my pickup truck bumper to push it up onto the trailer once. Worked pretty sell.
ac
/ Bucket Mounted Push Bar? #3
If you're doing this a lot Denaliakitas......does your loader have a QA on the front? You can buy plates for $130 or so on Ebay....put some tires on it and I think you've got a great way to push cars around.
In an automotive shop that I used to work at where we did a lot of "no start" diagnosis, we had a toyota 4-runner with a wood bumper with 3 tires attached to it. Pushed cars all over the place with that thing.
No my tractor doesnt have a QA setup on it. I am hoping to come up with something that can mount to the bucket pretty quickly like some of the bucket forks do. All i really need is a single vertical post or something thats padded so it doesnt scratrch up whatever i am pushing. Basically want to be able to push non running vehicles into the shop to work on them.
/ Bucket Mounted Push Bar? #7
do you have a toothbar on the bucket...if so, I'd hang tires from the teeth, point the teeth up so the tires don't fall off and push away
/ Bucket Mounted Push Bar? #9
Tractor Supply has a hitch plate just about what you are looking for. SKU # 1891593 It is called a Pintle mounting plate. It is sold separately from the pintles and fits a 2 in. receiver.
Tom
/ Bucket Mounted Push Bar? #10
Don't know if this will work for you, but I built a wagon tongue type bar that I use to push/pull stuff around. I took a 10 foot piece of 2" pipe, welded two pieces of steel (with holes for hitch pins) on each end. It looks like a double ended wagon tongue. Hook one end to the tractor drawbar, the other end to the drawbar or receiver hitch of the disabled vehicle. With this, I can move whatever vehicle needs moved, using the tractor brakes to stop it. Just have someone steer the dead one.
No chain, no scratches, no runaways.
2008 23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
2008 23ft. Zodiac...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
4004SFL (A59228)
4004SFL (A59228)
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
1988 Ford Mustang GT Convertible (A61574)
1988 Ford Mustang...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
