bucket snow plow exerience with a GC-series tractor?
   / bucket snow plow exerience with a GC-series tractor? #1
FredWalter
Southwestern Ontario, Canada
John Deere 5300, Gravely 8163G, BCS735, etc
Is anyone using a snow plow that attaches to their loader bucket, on their GC-series tractor?
Any thoughts/experiences/stories?
   / bucket snow plow exerience with a GC-series tractor? #2
In my opinion, the bottom of the bucket on a GC is too thin to do this without either extensive reinforcement.
I made a frame, and attached the plow directly to the loader arms.
   / bucket snow plow exerience with a GC-series tractor? #3
I've used mine several times recently, only to scrape off the 1-3" of snow and/or ice from a paved driveway. It works, but it's sure not very efficient compared to my blower! (Just removed the FEL and put the blower on for the season yesterday; I was a little late this year?:ashamed:)
irvingj
   / bucket snow plow exerience with a GC-series tractor? #4
Hi FredWalter,
I have started the snow season for 4 years now using my bucket in the float position with the front edge of the bucket raised to begin packing snow on my gravel driveway. As the season progresses, I will switch to the MF blade, and then again switch to the MF snow blower, :2cents:. Hope this might give you some ideas, :tractor:. KC :D
   / bucket snow plow exerience with a GC-series tractor? #5
I used a 7ft Snowbear on mine for 2 years and never bent the bucket at all. I just drilled two 3/4 inch holes through the round stock on the plow and into the bottom of the bucket, added a flat washer on the top and bottom and tightened it down. Worked like a champ. Only reason I stopped using it was that I found JD hyd lift and angle and made a mount that adapts it to the GC and now use it. If it were a heavier blade like a Meyers it may cause some issue but the Snowbear is only about 170-200lbs.
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
1999 CHEVROLET C7500 UTILITY TRUCK (A57880)
1999 CHEVROLET...
2001 Freightliner MB55 Chassis Bus (A56858)
2001 Freightliner...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
SAMSUNG REFRIGERATOR / FREEZER (A54757)
SAMSUNG...
