Bucket Thumb install finished
   / Bucket Thumb install finished
I've been looking for a grapple to pick up logs and brush but can still be removed from the bucket easily when it's not needed. It looks like that grapple can be removed by pulling three pins and disconnecting the hoses. How does it do with picking up logs? I'm curious, what was the reason for mounting the grapple on top of the 3x5 square tubing?
I've only tried it on one "test" log that was only about 9' long and maybe 16" diameter. Tried it two ways, both worked fine: (1) float the bucket, gently slide the teeth under the log until the bucket starts to push it, clamp down, and curl the bucket back. (2) Under some circumstances if there's plenty of room above the log, I could open the grapple, raise the bucket about four feet and curl it down 90 degrees, ease up to the log (this way I can see how close I am by looking under the bucket teeth hanging down), drop the whole thing onto the log, clamp, and curl--just like you would pick up a small stick of fireplace wood with one hand.
The rectangular heavy wall tubing was used to get 3" of rise for the base mount above the bucket top, which allowed the grapple tips to contact the bucket teeth just right when it was closed (cylinder fully extended), and at the same time give me the widest "bite" when the cylinder was fully retracted. Using rectangular tubing also made bolt-up easier. I could have arrived at the same operating geometry with a 24" long x 5" solid steel wedge on top of the bucket, but the wedge would have had to be about 1/4 thick in the back and 1" in the front to gain the proper angle. Not an easy thing to come by. A wedge-shaped mount would have also made bolting everything to the top of the bucket a little more complicated.
   / Bucket Thumb install finished #12
Looks good:thumbsup:
I also have and Green's Machine thumb and a Markham tooth-bar.Great tool.
Great for brush and logs.Mine is also bolt on,for easy removal.
Saw the writeup on yours, nybirdman. It was one of the things that inspired me to go ahead and order this one. Like you said, it's a great tool to have, at less than half the cost and about 1/4 the weight of a regular 48" grapple. I bought an extra base for mine, will try to figure out how to adapt the extra base mount to fit my Chris Perry fork setup. Then I can swap the grapple between the bucket and the forks by just pulling three pins and two QC's. If I can get it done it will be a handy setup.
Also: Didn't like the snap-on safety pins, I'm pretty sure brush would catch on them and jerk them off. So I drilled out the holes in the 1" mounting pins a tad and used small linch pins. Only needed to drill the pins a little, I used a 13/64 bit--easy and quick to do.
   / Bucket Thumb install finished #14
Looks like a job well done.
I have to say that comparison that magicheater gave does not do my loader any favors....gasp!
   / Bucket Thumb install finished #15
picker77.........I replaced the pins with bolts....kept losing the pins in the brush.The only problem that I have had is:if you roll the bucket (with the thumb full open )and push the thumb beyond the range of the cylinder it will lock open.Just remove the top pin,lower the thumb,reinsert the pin.Takes longer to explain than to fix.Nice tool enjoy.:thumbsup:
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Peterbilt 579...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
1607 (A57192)
1607 (A57192)
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
