"Budget" Barndominium Build Begins
   / "Budget" Barndominium Build Begins
Update- footings are all in and started working the tin around the sides. Window frames/windows in progress this weekend, then the roof goes up soon.
Windows going in.........
Pad for the AC/heating unit.....
Back wall/footing with the pad poured for placing the rainwater collection tank in the background.
Steel fits down in the lip for a good seal....
Exterior is much faster than the framework. All walls except for the living area front are up and the windows are in. We did a 4 foot overhang on the 2 stalls and an 8' one over what will be the porch.
Living interior space....
Up close
Dividing wall- mucho insulation coming up!
Pretty good fit
Gutters going up for rain catch system.
Slab poured and plumbing in place...........
Time to add the overhang on the front porch........
Interior work progressing nicely- exterior metalwork pretty much complete. Now the framing and walls are going up inside-
Front windows are 48"- plenty of view...
After the framing comes electricity, then foam insulation, then finishing out the inside, adding the HVAC and rain catch system.
Interior walls are all up and the plumbing is ready to go. Electrician is coming out this weekend to get started up. Once he's done, it's insulation time then foam spray-in insulation.
   / "Budget" Barndominium Build Begins #17
Great progress. I really like that view you have too!!!!
Eddie
Thanks! It's 400 yards to the next fence and the closest neighbor is over a mile away.
Foam insulation completed and the front is now buttoned up with door and windows.
Interior foam shaved and ready for walling in.
So far we're using recycled 4 and 6" fence boards- like the look.....
   / "Budget" Barndominium Build Begins #20
Very nice! Did you do the foam yourself? Like the insulation but far too expensive up this way for a 'budget' build.
(10) 2" X 6" X 24" TUBING (A54756)
(10) 2" X 6" X 24"...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
2002 R/S Body Co Dump Trailer (A47477)
2002 R/S Body Co...
Duetz Power Unit (A50120)
Duetz Power Unit...
UNUSED LANDHONOR LHR-G209 ANCHOR SHACKLES (A54757)
UNUSED LANDHONOR...
2005 Ford F-650 2,000 Gallon Water Truck (A55788)
2005 Ford F-650...
