- Joined
- Aug 31, 2001
- Messages
- 66,040
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Well, I've always wanted a backhoe, but could never afford one for my old IH tractor. New ones were close to $8000 and used ones were over $2500 and junk. I started looking at the Cadplans units and found that the model 821 looked to be a nice kit to build. It has good specs and will do the work I would like to do. It is also towable behind a car and self powered. I found I could build one for under $4000 after all is said and done.
Then I bought the Power Trac PT425 in 2001. I had no more money in my budget, so the backhoe had to wait. We sold the IH last fall and that gave me some cash in the tractor budget again, so I re-started research.
I confirmed that the PT425 will run the Cadplans unit with no problems. The kit calls for an 8HP engine and the pump puts out about 6GPM at 2000PSI. The PT puts out 8GPM at 2500PSI, so if anything, it will overpower the unit.
I will not have to by an engine, hydraulic pump, reservoir tank and a couple other items, as the PT will provide the power and hydraulics for the unit. That should knock off at least $600. /forums/images/graemlins/smile.gif
As designed, the unit is able to operate by itself with a couple hundred pounds of counter weight. If I put a quick attach plate at the rear of the unit the PT should act as a larger counter weight. It should be very stable.
At work last week they were scrapping huge machines. I was able to score four pieces of square steel tubing that are 4" X 4" by 72" and a tad over 1/4" thick. Closer to 3/8" thick. Plus, both ends of the tubes are reinforced with an additional 1/4" of steel all the way around! I was also able to get 6 pieces of very thick C shaped channel about 72" long as well. On top of that, I got about a dozen 1/4" steel triangles that are about 18" at the base and a foot tall, plus a couple of 2" X 4" X 3/16" thick tubes of various lengths. So I believe I have enough steel to make 95% of the unit FREE! The only steel I will need to buy is some 1" ID X 1.5" OD DOM tubing and some 1" rod. That is used to make the pins and bushings. That stuff is expensive and will run around $250-$300. I will also need about 8' of 1/2" X 3" plate steel and possibly some 12" X 12" pieces of 1/2" plate.
Then I will need three hydraulic cylinders for lift, dump and curl and an additional cylinder for swing. I will also need the hydraulic valves, hoses and connectors. I'm hoping to keep that under $1200. If the budget holds, I will add a hydraulic thumb as well.
The Cadplans units call for manual stabilizers, but again at work, I scored four 18" hydraulic cylinders. They are not large enough in diameter for the backhoe, but will be fine for the stabilizer legs, I think. I will use one for each leg.
Yesterday I was surfing some welding and machine forums and found several free plans for backhoes. They were very complete and well thought out. So I will skip the Cadplans and go with the free ones. That saves a few $$$.
Hopefully, when the entire thing is done, I will get away with less than $2500 and it should be a very beefy unit. I am not planning on starting it soon, so this will be long term project, but I wanted some input from anyone with any thoughts, concerns, suggestions well before I start the project. Over the next year I will post progress and, of course, pictures. Looking forward to any and all comments regarding this project and how it relates to our PTs. /forums/images/graemlins/tongue.gif
