Backhoe Build A Backhoe For PT425... It Could Happen
   / Build A Backhoe For PT425... It Could Happen #201
Thanks for the advice; I will give them a call. I'm not quite ready to buy just yet, want to get my ducks in a row first. The attachment plate looks to be 2/8's of an inch, not that thick. I am guessing it would need to be reinforced with some kind of plating at the base? /forums/images/graemlins/shocked.gif
   / Build A Backhoe For PT425... It Could Happen #202
Unfortunately, I do not have any welding equipment, and haven't done any welding since high school. I would have a local welder do the work. A welder is on my wish list for later on. If nothing else just to make a few simple attachments. For now, I just want a working mini hoe for some of the more aggressive projects around my house.
   / Build A Backhoe For PT425... It Could Happen #203
MossRoad:
I am wasting a lot of time trying to find free backhoe plans, and I see you have had some success. Could you supply me one or two links you thought were good?
I have recently purchased 100+ acres of NC clearcut land, and there is a lot of work I need to do on the property, to include some ditching. I have to tell you this is an investment but it has eaten up all my financial resources...to hire out the work will be VERY expensive.
Thanks and Best Regards, Brian Banks
   / Build A Backhoe For PT425... It Could Happen #204
pretty cool. 100 acres? And my dream is 10 acres (of course, property near Seattle is pretty spendy)... where did you buy?
Here's the URL to the vintage farm plans page. http://www.tapintothenet.net/vintagefarmplans/page8.html
There is a link on that page to the portable backhoe. The plan is in two parts in PDF format. Save them to your hard drive. If you do a google search for Vintage Farm Plans and/or portable backhoe, you get lots of dead-end links. I checked this morning and the plans were still there, so get them while the link is good! /forums/images/graemlins/grin.gif
   / Build A Backhoe For PT425... It Could Happen #206
Tim:
I bought in Cumberland County, just outside Fayetteville, NC. I retired out of Fort Bragg and stayed in the area. NC gives a tax incentive to anyone who "tree farms", basically grows pine trees in the state, and it appears to be a lucrative thing to do to help avoid some of my state and federal taxes.
Brian
   / Build A Backhoe For PT425... It Could Happen #207
Thanks a million. I had chased that link down before and as you said it was a dead end, at least the version I found. THe one you sent me worked, and I have taken your advice and saved the files to the hard drive.
I shall be scrounging parts and will try and keep this forum posted on any progress.
Best Regards, Brian
   / Build A Backhoe For PT425... It Could Happen #208
David, Now that I have every thing welded together, and tested the cylinders, I have found some problem areas. These problems were only apparently in the testing phase. One being that if using larger cylinders, to allow more clearance for the larger cylinder. The other one is on another cylinder shaft touching the 4x6 in the extended position in the roll over position. I have to modify the mounting holes for the boom, and one cylinder bracket. Smaller diameter cylinders probably would have worked, but I used what I had. My advice would be to tack every thing together, fit the cylinders in place, and rotate evrything through several cycles. I used the aux hydraulic lines to operate the cylinders. It makes a good test valve. After everything is built and tested, I will plug into the PTO circuit and use inline adjustable flow control valves to control speed.
Thanks for the tips. The instructions I have tell me to do this as well...
Test for proper fit and clearance. Grind where necessary. /forums/images/graemlins/grin.gif
Started welding tonight. I wanted to wait until I had all the pieces cut before starting to weld, but realized that would be impossible, since I am not strictly following the plans. I needed to weld the first piece on the frame so that I can measure, cut, drill and weld the two brackets that will hold the top and bottom of the boom pivot assembly.
So, here's a couple pictures of the first two pieces going together.
1st one is a side view of the main frame tipped on its side. It is 48" long. The piece I welded on is about 6" long.
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
UNUSED AGT SDA-140T LOADER (A51243)
UNUSED AGT...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
