gabeancounter
Project 28x50 pole barn with first 3 bays enclosed and other 2 will remain open. Want to use standard shingles for roofing instead of metal. HOA will not let the siding be metal etc.
Roof trusses @ 24" OC. 26 trusses total. I have calculated the cost to build (w/ free labor) the trusses at $33 each versus $68 plus delivery. $900 savings equals worth the effort!
28' trusses with 1' overhang is the largest I can build with 16' lumber. According to the plan below, I will need 5 1/2 - 2x4x16 and a little more than a half sheet of 1/2" plywood.
I am able to purchase 2x8x16 SYP for $8 versus 2x4x16 Whitewood for $6 -Is it better to rip the 2x8's in half? Any problems doing this? The boards will be a little thicker than a standard 2x4 by using this method. The southern yellow pine is heavier and seems stronger than the whitewood? I have a good tablesaw to rip them with. My other question is that the plans show not cutting the inside braces with any angles just letting the plywood gussets hold it together- any problems?
Thoughts?
Thoughts?
