Build your own roof trusses -advice ?
   / Build your own roof trusses -advice ? #21
I built my own trusses last year make a jig and save yourself a lot grief.If you make a fixture you won't have any difference in the size of your trusses,if you don't you will.
I built mine from 2/6/16 ft.It took about 10 days after work at night and they are about all 1 person can handle by themselves.
I went 2 ft on center Osb for the roof and I used shingles.Last winter it had over 2 ft of snow on and no problems,it was a 6/12 pitch.Good luck and enjoy!
   / Build your own roof trusses -advice ? #22
Lotta guessin' goin on in here, except for schmism.
Without stamped, engineer design drawings, & building them precisely to those drawings, 1) you're at risk of something failing & damaging yours or others' property, & injuring/ killing yourself or others; 2) You have no documents for a codes/ building inspector, if they're ever needed; 3) You have no professional, expert source to get documented answers to the variance questions you're asking (splitting 2x8's, etc).
Most posters in here are guessing based on their experience - That would "probably" result in a sufficient building, but who knows for sure??! It's such a nominal cost to either purchase professionally made trusses with professionally designed and approved engineering drawings, or at least get professionally approved engineering drawings that you can build the trusses from yourself, making sure to ask all the engineer all the money-saving questions you have for incorporation into the design & drawings ... & the pro-made trusses may actually still come out cheaper. And you'd have more time for other things :thumbsup:
   / Build your own roof trusses -advice ? #23
As a previous truss engineer...............
...............Id ask the truss manufacture to price out an 8' OC truss instead of a 2' oc truss. you might be surprised to find its cheeper to go that route as there are only 8 required for your 50' building.
Id also inquire at the truss manufacture about putting together a kit for the building including all the purlin material for the roof and for the sideing as well as posts. You may find his price on material for a kit for the complete building (with all materials delivered) is very comparable to what you can buy the materials yourself. you can see significant savesings if he uses a composit posts plating treated material on the bottom and regular material on the top. a 3 ply 2x8 post will be MUCH less expensive than a 6x8 post
This is good advice. When I did my 30x40 with a shingled roof, I got a better deal using 2x6 trusses on 4' centers w/ 2x4 purlins, and 1/2" decking. The barn package suppplier recommended it as a cost saving alternative, and it yielded a higher load rating than the standard 2x4 trusses he was selling. As a bonus the extra spacing makes the trusses much easier to use for overhead storage. I have not noticed any sagging at all in five years.
   / Build your own roof trusses -advice ? #24
I wouldn't even consider building my own trusses. I shopped around, and the cost here was pretty cheap. And unless you have a jig set up, you won't get 2 that look alike.
Bearcreek, thanks for the pics. The build looks great. :thumbsup:
I will get some additional pricing on the trusses. I don't understand what has changed over the last 20 years that now require newly engineered stamped, dense grade wood to build a truss. These plans have worked for decades.
Was there a rash of roof collapses in the past? Has anyone built there own and had a problem with every truss being different sizes? Any pics of these issues? We built our own 16' trusses 25 years ago off a basic design and never had any issues.
   / Build your own roof trusses -advice ? #26
Hurricanes, tornadoes & earth quakes happened ... & insurance companies don't like having to pay out money :eek:
   / Build your own roof trusses -advice ? #28
As mentioned before, buy commercial trusses designed for 8' centers and be done with it. I build a lot of barns and I'm done with 2' center trusses. They are built with such shoddy lumber nowadays it's hard to keep them from twisting and warping, even after being fully braced. Then you end up with an uneven roof surface.
The 8' OC trusses are much more substantial and less likely to warp in my experience. They are also a lot quicker to go up and make for a sturdier building IMO. Don't waste your time trying to build them, when you add up all you need and factor in even a small wage for your time you won't be money ahead.
   / Build your own roof trusses -advice ? #29
Your not suggesting he use trusses 8' on center for a roof that is going to get asphalt shingles are you?
MarkV
   / Build your own roof trusses -advice ? #30
Building codes have existed a lot longer than 20 years and they are updated based on engineering standards. If you were building under the 'Southern Standard Building Code' and were financing the structure through a bank etc., they would require engineered trusses and you would not even be issued a permit until said engineering was submitted and approved.
In municipalities that use strict enforcement of building codes certified engineering (stampmed documents) is required to reamain on the jobsite attached to the permit.
That said, if you are not required to have a permit and or inspections you can build whatever you want using any method you want. However if you intend to insure the structure I would suggest checking with your agent and make sure there would not be any ramifications down the road.
   / Build your own roof trusses -advice ? #31
While your trusses may or may not last, by attaching your chords to the sides like you did, you have lost a tremendous amount of strength. Nails are not load bearing fastnerns. They are to hold things in place. Relying on nails to hold the boards in place on the sides like you did puts all the weight of the roof on the nails instead of the lumber.
When the boards are cut and fitted together, the triangles created in the truss actually force it to stay in position. The downward preasure from the peak forces the boards into each other so that it cannot move.
The gussets are there to keep the boards where they need to be. They are not load bearing. The load is on the lumber. This is why the lumber used is so important.
Ripping lumber means that you migh be splitting the board right at the center of the rings. Ideally, you don't want this type of grain anyway, but by ripping it, you just make it worse.
I wasn't aware of the requirement for 3 inch nails, but it makes total sense. The strenght in the nail as a holding fastener is in the amount of shaft that goes through the wood. The point does not hold the nail in place and offers nothing of benifit other then starting the nail. Having the nails go all the way though the wood is critical in shingles, and it makes sense that it would do the same on wood gussets. Cutting off the tips after they go through the wood would be for apperances. The holding strength wont change any.
I like the second truss design A LOT better. That is what I make and use for myself.
Eddie
   / Build your own roof trusses -advice ? #32
Yeiks, in all the places i would scrimp and save.....it wouldnt be in the trusses. Not sure about where you live, but here the snow load engineering is something i wouldnt want to mess with. When my trusses were delivered and installed, a few had to have an onsite repair done. They used a hydraulic press to install a rather nasty looking plate...not the simple plate like lowes has. This thing took alot of power to install.
   / Build your own roof trusses -advice ? #33
MarkV
Went back and reread his original post, I forgot he was shingling it. Regardless, I still can't see making your own trusses as much of a money saving venture.
   / Build your own roof trusses -advice ? #34
Mike,
What type lumber are you using? (HD and Lowes #2?). The advantage to ripping in half was saving $4 per cut :D and the wood possibly being stronger than standard spruce. Would you use 7/16 osb and 19" spacing or 19/32 osb and 2' spacing?
GA, In NH KD spruce is available in box stores & real lumber yards . I go with whatever is the straightest. I use 1/2" fir plywood, never OSB, for gussets & sheathing. I wouldn't use southern yellow pine as it tends to be brittle/splits easily.
According to Beppington & Schism almost no one can do anything unless they have a title deposited on them by some bureaucracy, however many successfully complete this type of project following simple, standard, time proven designs. I use the W truss mostly for your length. 2" ring nails work at least as well as gangplates if enough are used. Nails are cheap, use enough.
Bearcreeks design has inherent weakness as described by Eddie, relying on shear strength with that few nails is risky. Cutting pieces to fit is really easy considering each cut makes two angles if you planned things correctly. It's rigid geometry that allows trusses to succeed. Talk to most professional firefighters & you'll hear that trusses should never be allowed. For 300UGUY to say that one cannot make two trusses the same must merely describe his carpentry skills. Measuring the triangles before nailing keeps things the same.
Good luck with your project. I wouldn't wish an HOA on anyone, hope you don't end up hating your neighbors. MikeD74T
Mike,
I have to say you must be a mind reader! That is my exact thoughts. I was trying to be pc, but you put it on the line. :thumbsup:
I just can not understand a piece of metal pressed into a joint being stronger than a 1/2" sheet of plywood 4-5 times its size supporting a much larger area.
Seems it would distribute the weight better?
I do agree on dumping the idea of spliting the 2x8. I think I will use the 2x6 top chord as well suggested by Eddie. The second plan seems to be a better plan and the one suggested by Monte Burch - "Pole Barn Projects". Making these adjustments will probably but the cost closer to $40-50 per truss. I will let you know.
The other advantage is this is a weekend warrior project. Don't really have time to take off to meet and schedule truss delivery etc.
Do you normally use laminated post? If so, adhesive you use? I notcied Morton building and other large outfits change over from PT to standard spruce above ground. Is this purely a price savings - or is there an advantage?
   / Build your own roof trusses -advice ? #36
To build anything over 600 square feet on my 10 acre place, I need a building permit. To pull the permit you need wet signed engineering drawings and if trusses are used, these have to be built by a certified fabricator. So around here it's a no brainer--no home-made trusses if you want to stay legal and build with a permit. And the county checks real close on any new construction they see in their periodic driveby inspections. If there's no building permit on file for your new shed or whatever, expect a letter in the mail followed by a visit from the building inspector.
   / Build your own roof trusses -advice ? #37
Mike,
you wouldnt believe how easy it is to RIP plywood with shear force. Ive seen it first hand after working in Calif after the 1994 earthquake, and this was 1/2" cdx. The areas with metal straps faired much better than the plywood joined sections.
I do plan to pull a permit and have spoken with the inspector. Ag buildings/ sheds etc are different than living space requirements.
grs, are you referring to plywood gussets and metal gusset plates? or sides of buildings etc?
   / Build your own roof trusses -advice ? #39
You are not understanding the purpose of the plates or the plywood in a truss design.
Neither are there to support the load. They are there to keep the ends of the lumber in place.
When the truss is in poistion, the lumber pushes into itself to lock it into position. If you where really good, and lucky, you could assemble a working truss without any screws, nails or plates. The ends of the wood would wedge into each other like a keystone, and it would stay in place. Since that's not possible, you have to use fastners to hold them in place. Either metal plates of plywood will do this. It's not about the stregth of the plates as much as it is to make sure they wont let the wood move.
Trusses fail for a variety of reasons, but when tightly built and sized accordingly to their span, they are VERY strong with very little weight.
Eddie
Eddie, you are right. I guess it is dispersing the stress of the connection more than the actual weight load.
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
Deere 310L (A53317)
Deere 310L (A53317)
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
2017 JOHN DEERE 470G LC EXCAVATOR (A60429)
2017 JOHN DEERE...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
