Building a fence near a power utility pole?
   / Building a fence near a power utility pole? #21
Around here where I live the power pole would most likely be turned into a fence pole with the wire stapled right to the side of it and the power company would not bat an eye. They routinely work with farmers and have a pretty good working relationship with them. Of the farms I've worked on and my place the power company or contractors work to inform what needs to be done, work around harvests to get things done without any standing crop damage, work with livestock owners and property owners as well.
   / Building a fence near a power utility pole? #22
Here in Texas, I already had the fence in place when the power pole was installed. They insisted that it be on my property, inside the fence. There is probably a foot between the pole and my fence. I cannot mow around it, so I weed eat there.
I guess that you have your reasons for having the pole inside the gate area. If it was me, I would slide the gate over so I could get through the gate with a tractor or vehicle.
My thoughts exactly. Why put a wide gate with a pole that restricts the width by several feet. Just put the end of the gate even with the pole.
   / Building a fence near a power utility pole? #23
My advice is DON'T BUILD ON THE POWER COMPANY'S RIGHT OF WAY unless you are going to keep the trees down to their satisfaction. I live on a hill side near town and have a well built dog pen with trees near the fence. On the last two occasions after they've left, I found damage to the fence consistent with a limb having fallen on it. Once it was half-donkey repaired in a way I'd never have fixed it. The other time, I discovered a bent horizontal conduit several months after they'd left. Neither time could I find a rotten limb that was placed there by the wind. On one occasion they parked the bucket truck on the drain field of my septic tank.
On the other side of the house is a very steep hill. When we moved here it was all grown up and I considered it to be woods. Then, they cut down twenty or more ft. tall trees beneath the line and left them where they fell. The old lady next door gave me bricks about the mess and it took my son and myself many years to work it out of the way. Last year they came back and cut limbs and saplings, chipping a few, putting some into the woods, and blocking a road that I'd cleared with others.
The farm is another nightmare. My pastures are severely overgrown and the crews almost always drop limbs on the fences often causing me to have to round up cows and repair fence in the hottest kind of weather.
Being 69 years old, I'm divesting myself of cows and wish there wasn't a single power line near my fences or within reach of any of my trees that might fall on them.
If you're willing and able to keep the right of way mowed for the rest of your life things might go well. Good luck.
Here the tree pruners do a good job of not damaging your property. If they do, the energy company is liable for repairs. They have right of way access, but that doesn't release them from the liability of damage to your property whether it be rutting up the land or physical damage to existing structures. I always watch the tree trimmers when they are trimming around my fences to make sure they dont drop a limb on my fence "accidently".
[OP here] The power pole is on my property next to a private road which is entirely on my property.
I'm going with the design I described previously, with a large gate opening to provide access to both sides of the pole that I can drive by tractor or truck through as well - probably a 12' gate.
Thanks for the input, everyone. I have few concerns about tree crews messing things up as I deliberately put off this project until after they did a ton of work last month and they're unlikely to return for a few years for minor work.
My experience with them (tree crews) - generally good; I found a few crushed water bottles (litter) and there was only one tree damaged collaterally which I had them add to the list of trees to remove. They didn't touch a couple existing fences despite having to remove a 130' ponderosa pine which was a yard from it. I did get a humongous pile of shreds too which I'm gradually spreading all over the place.
I had one yard plant that got hit (pomegranate bush) and its water line got broken; they offered to replace & fix but I needed to have the water asap so they gave me the $100 I requested (for a new bush and plumbing supplies and some of my time - manager drove out and gave me cash lol).
   / Building a fence near a power utility pole? #25
To me there's a huge difference between a 12 and 16 ft. gate. I always dread going through my 12s. If you'll use it a lot, go with a 16.
   / Building a fence near a power utility pole? #26
I have two gates on my driveway. The inner gate is where the mile long, straight as an arrow, driveway turns to the NW and goes into the yard. It's a 20 and boy am I glad. Anything less and I would have to straighten out the Taco Wagon before I go thru. And I need every foot of that 20 when I plow snow in the winter.
   / Building a fence near a power utility pole? #27
16 is ok, 20 even better. A 12 is a pain!
I'm guessing I'll use the gate at most a few times a year with the tractor. It will access a garden area.
   / Building a fence near a power utility pole? #29
Still, I wouldn't go smaller than 10' usable and I would try for 12'
Aaron Z
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
greenworks (A53421)
greenworks (A53421)
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2016 IZUZU NPRXD S/A BOX TRUCK (A52706)
2016 IZUZU NPRXD...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
