Building A Home Car Wash
   / Building A Home Car Wash #12
I use my well that out in the pasture,, I run it off a welder/generator,, most of the piping is one and half inch.. I installed a 3/4" valve fitting for a hose off of one of the 90's,, with only the pump running I get around 60 psi and maybe eight gallon a minute flow thru that 50' by3/4" hose,, I use it to wash farm equipment,, it does a nice job,, plus my pasture gets watered at the same time.. but make sure you lay a large rock on it when not holding it,, there is no cut off unless you unplug it.. it will walk like a snake and that brass fitting on the end hurts,,, I know.. Lou
   / Building A Home Car Wash #13
Just wondering out loud here. But since you have pressure from your well, could you buy a pressure boost. That way the water would come in hit the boost and then you could have your manifold to apply soap or water etc (thinking something like a pex manifold). You could then run it out to the outside. I would think instead of a boom pole what about a self reeling hose assembly like they have for air compressors. That way it could still swivel but would be out of the way. I really like the idea of a home carwash especially since we live on a modified stone road, with a modified stone driveway.
Riptides - those booms start at $900 very nice, but I like the economy setup in the link better, just a need to find a swivel pole to hold the hose.
aclan - I was thinking along those lines until I saw the setup in the link. What would be the advantages or disadvantages of a simple $120 electric pressure washer instead of the $1000 wall mounted 220v washer? Volume? Longevity? Pressure control? Soap siphon? I'll have to look at some specs.
Chasemech and Lou- That is the best benefit of the car wash it will no longer be ME. (Well, that's the game plan anyway.)
Kieth - I will try find aluminum first and steel second, I don't want a wooden boom. I really need to find that 10' Aluminum L - that's the hold up right now.
Forgeblast - I like the boom instead of a reel because as Yago says: "I strongly recommend having this arm (boom) as it keeps the pressure hose clean and off the ground, and keeps it from getting hung up on bumpers and tires as you move around the vehicle."
   / Building A Home Car Wash #15
Benefit? Price.
$20ish will get you a soap injector such as General Pump Quick Connect Pressure Washer Detergent Injector — 3500 PSI | Detergent Injectors| Northern Tool + Equipment
$60ish will get you a 50' hose such as Non-Marking Pressure Washer Hose — 4000 PSI, 50ft. Length | Pressure Washer Hoses| Northern Tool + Equipment
$100ish in parts will get you the boom made
Disadvantages? You will probably never have to replace the pump in a $1000 system, you might have to replace the pump in a $120 system (the $120ish pressure washers are available for $75 or less on Craigslist). The soap injector I linked to might not work as well, but you could also get one like he had in his article.
Aaron Z
   / Building A Home Car Wash #16
A hot water heater might be nice, especially if you are washing the car in the winter, but probably not necessary.
Probably not, only had 3 or so days of freezing this winter.
   / Building A Home Car Wash #19
You should be able to get the angle at your local metal supplier.
I might get a electric 1500 PSI pressure washer ($120 for a new one?), then mount it to the wall, add a longer hose, the boom, etc, mount a tank for the detergent with a shutoff (lever going through the wall to close a valve on the soap line?)
Could probably have it setup for under $400.
Aaron Z
Stay away from a electric pressure washer they are junk. I had one and it lasted 10 minutes.
   / Building A Home Car Wash #20
You should be able to get the angle at your local metal supplier. I'm Sure Harv has some sitting around :)
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A53843)
2013 XLR...
2012 Freightliner M2 Chipper Truck (A52377)
2012 Freightliner...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2023 Load Trailer (A55787)
2023 Load Trailer...
