Building a pole barn, but what to do about doors?
   / Building a pole barn, but what to do about doors? #11
Hold on there. New member, first post and only two pictures. What's the big idea? I need to see some more pictures of the inside of your building. Pole building with block base?
I was wondering about that myself! BTW: :welcome:
   / Building a pole barn, but what to do about doors? #12
You can buy premade stall doors. I see them in horse magazines. I use 1" square tubing, sort of thick walled, my cheap metal bandsaw and my Hobart welder. I skin with plywood. The joy of homebuilt is my openings are around 48" give or take 1/4" which could be frustrating. My big sliding doors were done on a frame of 1.5" square tubing allowing me a 11"' wide and 10' tall opening to drive the hay trailer through.
   / Building a pole barn, but what to do about doors? #13
I like the idea of metal frames on the doors. We always had dutch doors on the old barns, but even when they were only 3 feet wide, we would have sagging problems over time. With 4 foot width, I think metal bracing and lots of hinges would be a good idea.
   / Building a pole barn, but what to do about doors? #14
Hi Mike and Gizmo2,
I live in Florida, but the barn is in Georgia at my cabin. We have had numerous tornados over the past 10 years in and around are area. Reason's for the block, at a later date I want to put decorative stone on the block to dress it up. I feel it looks better because of the splash back from the drip edge, and most important, I anchored everything into the foundation to assist in the storms we have.
As for the doors, you don't have to worry about lossing space because of tracks, because there are no tracks. All of your hardware is bolted to the 6X6 and not into a 2 by, thus no hole in the tin. When the doors are up, it gives you a clean look and when they are down, they are VERY secure. Hope this helps, I will be in Georgia over the New Year, if your really want to see more pics, let me know. You all take care and have a Very Merry Christmas and a Awesome New Year!
   / Building a pole barn, but what to do about doors? #15
You can cut a channel in the loft, enough for the thickness of the door and put the drum in the loft.
   / Building a pole barn, but what to do about doors? #16
I like metal frames for the doors as well. Mine are out of 2.25" 12ga tubing, to match the rest of the barn, but smaller tubing would be fine. I went that big to be able to use 2x rough cut inside the frame.
2022 Schulte 2500 Giant Rock Picker (A55315)
2022 Schulte 2500...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
County Line 3pt Single Row Cultivator (A56469)
County Line 3pt...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
2018 Ford F-550 4x4 Terex LT40 40ft. Bucket Truck (A55852)
2018 Ford F-550...
