Building a shallow well
   / Building a shallow well #11
Around here its called a basement!
mark
well i stayed around 7 feet deep, i would fill about 5 5 gallon buckets with water for ever 5 gallon bucket of dirt. i just could not keep up with the water coming in the hole. so i went and got a 10 foot piece of 6inch PVC and drilled holes in it and put it in the hole. My first choice would have been a 15" plastic culvert but i could only find them in 20' sections and that was way more than i needed. so i backfilled with rock and then about 8" of dirt/clay on top of the rocks.
then i hooked the pump up and ran one garden hose wide open for about 35 min. and then it dried up, i have to wait an hour or two and then i get about another 35 min. the flow is less than i hoped but I was pretty uncomfortable with the hole being deeper than i am tall.
i would really like to use my post hole digger by adding sections of pipe. I just have not figured out the how i am going to do it.
all in all it is an alright well for $20 and 4 or 5 hours of my time.
I was really hoping someone would give me some crap and say "why do you need a well when you could use the frost free hydrant in the first picture" . well that water is pretty expensive around here, but now that think of it so is gas to run the pump i am using.
   / Building a shallow well #15
Mike, I generally think the safety police are too cautious but you are pushing your luck in that unsupported hole. A cave-in in a 4' hole can be fatal.
Anyway, I dug a well like that in my basement by digging as far as I could until I couldn't keep ahead of the water. Was in gravel & only 4' deep. I stacked up 3' tall concrete perforated drywell tiles one at a time as needed then got inside with my pressure washer & a diaphram type mud sucker pump. Ended up 12' deep. As I washed loose the gravel the pump sucked it out & the tiles settled into the hole. MikeD74T
2018 Dodge Ram 4500 4x4 Enclosed Service Truck (A48081)
2018 Dodge Ram...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
2019 Ford Transit 150 Cargo Van (A48081)
2019 Ford Transit...
1-Pallet Misc. Items (A50860)
1-Pallet Misc...
2017 Nissan Juke SUV (A48082)
2017 Nissan Juke...
