Building a toolbar for 3pt implements
   / Building a toolbar for 3pt implements #11
3/8" should be sufficient, but I wouldn't go any smaller. I went with the 1/2" for the strength and because they had a piece of 1/2" x 4 in their drop pile. I would definately go with 1/2" on the hook ups for the lift arms. I think 3/8" might bend there. 2 planters with the toolbar will probably weight around 400#. add in 2 bags of corn and you have about 500#.
Also, you need to measure your u bolts. John Deere planter toolbars are actually 2 1/4". I had to do some pretty significant grinding last night on the 2 1/2" to mount the planters. I would try to go with 2 1/2" bar and not tubing. If I had used tubing I would have ground almost through the wall of the tubing to get the bar small enough to mount the planters.
The planters are on the toolbar and mounted to the tractor. I plan to plant about 2 acres of Indian Corn and 1 -1 1/2 acres of white field corn when I get home today.
Chris
Chris, I decided to go with 1/2" x 3" and 1/2" x 6" for the hook up bars. I have over 36 feet of 2-1/4" diamond tool bar cut from the old JD 184 fertilizer unit I am taking apart so I am good there. My planters will weigh a little more that yours because I have the front packer wheels.
Great that you have the toolbar already. I think the 3" will be fine. I bought 4" because that was in the drop pile.
I planted 10# of Indian Corn in 30" rows yesterday afternoon. I ended up with around 40 rows that are 400 feet long. I also planted about 15#of Mosby's white prolific field corn. I will spray both when I get home today.
I will then start planting about 6-7 acres of Roundup Ready field corn.
I was on the tractor until midnight last night doing final prep work on the ground.
Chris
   / Building a toolbar for 3pt implements #13
...I planted 10# of Indian Corn in 30" rows yesterday afternoon. I ended up with around 40 rows that are 400 feet long. I also planted about 15#of Mosby's white prolific field corn. I will spray both when I get home today...
Chris
I won't be planting any corn until mid May at the earliest. I'll start by planting Trinity and then Peaches & Cream, followed by an Indian Corn. Usually we can't plant sweet corn until late May or early June. What will you be spraying Chris?
Steve
Round-up (kills any existing grass and weeds) Simtrol same as Princep (pre-emergent grass) and Atrazine (pre-emergant weed).
I plant in 30" rows. This is the first year I have tried the pre-emergants. I hope they work, because I don't have a way to cultivate the corn in 30" rows.
I will spray my RoundUp Ready corn the same way, but go back and spray again with Roundup when it's about 2' tall.
I was worried about the Mosby's germinating with the pre-emergants. I planted it on Saturday, April 3 and it took 7 days to start coming up. It's about 2" tall now.
Around here we usually plant Silver Queen and field corn as early as possible in April.
The Mosby's has an 85 day to maturity (Rossen Ears). That should put me hauling it to the Farmer's Market around June 28.
I waited 10 days to plant my second planting. Should be ready around June 7. My Third planting will be around the 21st of April. I should start hauling it around June 14.
Chris
   / Building a toolbar for 3pt implements #15
Materials List:
2 1/2" square bar -- 60" long
1/2" x 4" flat -- 60" long
1/2" x 6" flat -- 60" long
Cut 4 pieces of 1/2" x 6" x 6" long. I drilled holes with a 7/8" drill bit for the category 1 pins. I first drilled the holes 1/4" then 7/8". The measurements for the holes were 1 1/2" from the end and centered.
I then notched 2 of the pieces with a 2 1/2" x 2" square notch. I mounted these two pieces to the square bar 12 1/2" from center.
I then notched 2 of the pieces with a diamond notch. The are the reinforcement plantes for the top link mount.
I then cut 2 pieces of 1/2" x 4" x 24" flat. I drilled 7/8" holes 1 1/2" and centered from one end. I then took the same end and marked it at 6". I clamped the pieces to the forks on my loader and began to heat them. My neighbor (Jim) preceeded to sit on the other end of the 24" piece as it bent slowly. When we got it bent to our liking (I'll measure for you) we stopped. We then clamped the other piece of 1/2"x4"x24" to the fork beside the first. This way we could get our bends the same.
I used a piece of 2"x2" square tubing cut 2 1/4" long to space between the top of the top link mount.
I used 2 pieces of 2"x2" square tubing 3" long for stand mounts. Notice them on each end of the toolbar. I"ll get better pictures tonight. I took a chain link fence post and cut it in half and welded a piece of 2" x 1/8" flat to the bottom for stands. Drilled holes at the top and bottom.
It took about 4 hours to build.
I'll post one of the pictures from priming the toolbar. Notice I have it suspended from the ceiling with a chain hoist. It is too heavy to pick up by hand.
BTW: That 7/8" bit cost me $35.00 at the local hardware store. I like aprox. 50 miles from Harbor Freight so I had to buy locally. :thumbdown:
Chris
Firefighter....that is some great stuff. I was looking to make a single plow that would be off centered to the left, past my rear tires. The reason for this, is that I'm trying to clean out an irrigation ditch but can't get too close due to trees on that side. Wouldn't need to bury it, just about 4" so I can remove grass and other debris growing over it.
Your design could prove beneficial to me...thanks.
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
Towable Chemical Applicator Sprayer (A59228)
Towable Chemical...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
TEST YOUR BID BUTTON! (A60430)
TEST YOUR BID...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
